stripping black off of engine
  • jdbusch
  • jdbusch's Avatar Topic Author
11 May 2012 22:34
#521668
ok so my engine is paint black ( i guess factory?) whats the best thing to use to strip it down.
i really just want the aluminum look for the engine
Current:
1983 KZ1100-A3 Shafty
Gone:
1979 KZ1000-E Shafty
Email:
jdbusch1978@hotmail.com
  • pig9r
  • pig9r's Avatar
Re: stripping black off of engine
12 May 2012 10:45 - 12 May 2012 15:01
#521776
I use Aircraft Paint Stripper. You can buy it at local auto parts store. You spray it one and let it sit for 15 mins then wash it off with water. Stubborn spots spray it on and scrubb it off with a stiff brush.
(I posted a link to it, but it doesn't show. I guess I don't have enough posts?)
www.tcpglobal.com/AutoBodyDepot/ItemDeta...fw-q8CFQkEQAodvg2UDg
Last edit: 12 May 2012 15:01 by Patton.
The following user(s) said Thank You: jdbusch
  • Jusba
  • Jusba's Avatar
21 May 2012 10:22 - 21 May 2012 10:24
#523795
I think that Sodablasting would be good idea. I stripped paint off from my carbs using that method.
I'm also going to sodablast my KZ500 engine.
Last edit: 21 May 2012 10:24 by Jusba.
  • JEFFG1
  • JEFFG1's Avatar
21 May 2012 10:45
#523801
(pig9r) hit it on the nose very easy and fast used it on mine
Attachment DRAGBIKE222_2012-05-21.jpg not found
Attachment DRAGBIKE223_2012-05-21.jpg not found
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
  • jdbusch
21 May 2012 10:59
#523805
thnx guys i had to do my valve cover gasket, so while i had it off i tried the aerosol aircraft remover ( they sell it at my local parts store) and thanx cuz it works great
Current:
Gone:
Email:
  • JEFFG1
  • JEFFG1's Avatar
21 May 2012 11:08
#523808
i got the 1 gal can and spread it with paint brush dont know about aerosol ??
  • damarble
  • damarble's Avatar
21 May 2012 11:47
#523812
Will you leave it raw aluminum? I'd be worried about discoloring myself.. As awesome as polishing would be it would be ridiculously labor intensive. I would probably hit it with silver paint to keep it bright but protected (like is stock on mine).
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
  • jdbusch
21 May 2012 18:05 - 21 May 2012 18:09
#523870
well im thinking when i tear it all down and do the gaskets and rings im gonna strip it all down and sod blast it to bring out the shine then use a VHT HIGH HEAT gloss clear or VHT High Heat Anodized blue or base silver with a clear
im gonna do a blue and yellow color scheme on the tins and prolly a blue and yellow led kit. ( still undecided on the leds) so if i make the engine shine the leds wil glow nicely. dunno if plue paint and a blue anodized case will look right though. i may just do the aluminum case with a clear gloss and blue anodized accents
maybe an extreme high heat paint for the exhaust like flat black or yellow. yellow headers with a flat black muffler or vise versa
thinking about all these paint options
Current:
Gone:
Email:
Last edit: 21 May 2012 18:09 by jdbusch.
  • damarble
  • damarble's Avatar
22 May 2012 13:10
#524033
jdbusch wrote: well im thinking when i tear it all down and do the gaskets and rings im gonna strip it all down and sod blast it to bring out the shine then use a VHT HIGH HEAT gloss clear or VHT High Heat Anodized blue or base silver with a clear
I bet the blue will look great!
  • jdbusch
22 May 2012 14:52
#524045
yeah ive never seen it before so i thought id try it
Current:
Gone:
Email:
