2 week old paint, and already a chip...help
- Kjack90
Re: 2 week old paint, and already a chip...help
21 Apr 2012 13:15
this may work, but what if u take the kick start lever and dip it in that tool handle coating you can buy. you can get it in different colors and when it dries you get a nice rubber like coating.
1980 kz1000e2 shaft returned to factory airbox, with delkevic 4-1.
1982 xj650 bobber
2005 Suzuki Bandit gsf1200s
1982 xj650 bobber
- ChicagoLTD
22 Jun 2012 16:54 - 22 Jun 2012 16:55
Hopefully you found a solution for this, but if not Ive got a couple of the stock tank bumpers - if we get out and ride in Chicago I'll bring them for you.
1981 KZ550-LTD (bobber)
Last edit: 22 Jun 2012 16:55 by ChicagoLTD.
- faffi
22 Jun 2012 17:05
I have a roll of clear tape that can be used to protect book covers or shelves etc. Quite thick and very sturdy. I use it on the fuel tank where it meets the seat to prevent paint rubbing. Should work fine with your issue as well.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
1980 F1 engine
B1 Points ignition
22 Jun 2012 18:39
I like faffi's idea. Thats what I would do. Touch up paint and protect it with clear tape. Kinda like clear bug guard on some car front ends
- ramtough_63
22 Jun 2012 23:14
awesome bike!
I have a couple ideas may or may not work was just thinking what I might try
tape the frame off and scuff(in between the scratches) it up and try some Flex seal rubber spray havent sean how it dries but worth checking out. at least it will look deliberate or possibly spray bedliner in the rattle can from walmart is also a thought
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
23 Jun 2012 02:15 - 22 Jan 2013 20:05
listing ended
Last edit: 22 Jan 2013 20:05 by martin_csr.
- AjKZBobber
- New KZ rider...Long time dirt biker
23 Jun 2012 03:36
I had an idea to fix it using a rubber matting material that i had at my last job. it was sort of like the liner used for water barries under bath tubs. it was black and would have worked great, but i called a former co-worker to see if he could pick some up for me, but the plant is closing and it was already gone.
If only i could find some of that matting for bathtubs in black.
1979 kz750 b4 twin bobber
- wireman
23 Jun 2012 08:23 - 23 Jun 2012 08:29
Heat up the kickstarter and offset it a little bit away from the frame ,kind of like a box offset in a piece of conduit.
not a good picture but it gives you an idea anyway,just make sure bends cancel each other out so it comes out straight
Attachment offsets_htm_txt_Offset.gif not found
Last edit: 23 Jun 2012 08:29 by wireman.
- AjKZBobber
23 Jun 2012 22:44wireman wrote: Heat up the kickstarter and offset it a little bit away from the frame ,kind of like a box offset in a piece of conduit.
If I had the tools/equipment to do that, I would have already. I appreciate the input though.
I actually live in a condo building, so I dont have a garage of my own. So, no place to do any real work on the bike myself. I guess that I should have thought of that before I purchased an old bike.
- wireman
24 Jun 2012 04:43
Figure out where it needs to be bent,pull it off and take it to the corner garage and have them heat/bend it in a vice for ya for $20
