Headlight fairing interchangeability
  • 83Zrider
  • 83Zrider's Avatar Topic Author
12 Apr 2012 02:04
#515359
Hi wishing to find out if Gpz 550 Headlight fairing will fit the kz 750 L 1983. It would be nice to grab it up for good price. Thanks in advance.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Headlight fairing interchangeability
12 Apr 2012 05:13
#515371
Here is a terrible answer...yes and no. The opening for the rectangular headlight is close to the correct size on the 550 fairing to fit your motorcycle. Conversely, the 750/1100 fairing (the 1982 GPz750 and 1982 GPz1100 use the same fairing and mounts) opening is slightly larger and is the correct fairing (size-wise) for your bike. The differences between the 550 fairing and the 750/1100 fairing are ones of proportion (the 550 is a smaller motorcycle)...the overall size/shape of the 550 fairing allows it to be completely nested within the 750/1100 fairing. The mounting brackets (if they come with a 550 fairing) are designed for a motorcycle that is proportionally smaller than the 750L and as such, are shaped differently than the 750/1100 mounts. You will have to fabricate a mounting system for your L model (which didn't come stock with mounting brackets). That said, I have seen 550 fairings mounted on 1100's so it can be done, but mount fabrication is required.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: 83Zrider
