Raising rear of Duck Tail
  • badrhino
  • badrhino's Avatar Topic Author
09 Apr 2012 00:54
#514789
Has anyone raised the rear of their duck tale? I think it would look better at least on my bike with it raised a bit at the back. If you have done this could you please tell me how you did it. I have a few ideas but would like some input.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Raising rear of Duck Tail
12 Apr 2012 09:36
#515390
I made a bracket to raise the tail as well as mount a Zx12 taillight.
If you raise the rear of the tail too far you're going to run into issues at the front of the tail section in front of the forward mounting bolts.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • badrhino
13 Apr 2012 00:55
#515529
Saweet, that was kind what I had in mind but was going to try it with thinner aluminum or stainless sheet and cut/bend it to the form I needed and then just use bolts at all mounting points. I am using the R6 tail light so it might not be as complicated as yours or maybe it will be worse. :whistle:
Franken Z!
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
13 Apr 2012 20:39 - 13 Apr 2012 20:49
#515656
I raised the rear of my 650's tail an inch to fill the gap I created when I redid my seat, using a bracket I made out of aluminum, similar to Doug's.
Just 4 holes in a flat bracket, with two holes on each side one inch apart.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 13 Apr 2012 20:49 by rstnick.
  • badrhino
14 Apr 2012 02:51
#515697
Ok, thanks Guys. I was hoping it was that simple but the R6 tail light has mounting tabs placed vertically so I will definitely have to have a 90* bend in my bracket.
Franken Z!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
14 Apr 2012 08:55
#515716
i just put spacers under the rear monts untill it hit the seat bottom. then i cut the tops back, on the front of the tails arms,so it would lay on the frame better.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Drooz
  • Drooz's Avatar
14 Apr 2012 10:05
#515726
With mine, we actually bent the rear sub frame to raise the tail. The front of the tail (under the seat) needed to be trimmed to fit on the frame better as well.
I wasn't worried about "going back". :laugh: I love that "look"! ;)
If brackets work without exposing the frame too much, go for it!! :)
'77 kz1000 (zx10r) Modified/Street
'81 GPz550 "TrackBike"
'05 zx10r Retro/Mod Sportbike 4 SALE!!
'02 zrx1200r Lightly Modified Street SOLD!!
'74 h2b 750 (FZ600) "Mongrel" 2 Stroke SOLD!!
"Invictus Maneo" - I remain unvanquished.
Kawasaki - Let The Good Times Roll!
Mississauga, Ontario. CANADA
  • leitz
  • leitz's Avatar
14 Apr 2012 13:00
#515763
I used a bracket like Rstnick and Doug to raise the tail and other to raise the rear part of the seat to fit it with the tail.
