Gas Tank prep for paint
  • ThatGPzGuy
  • ThatGPzGuy's Avatar Topic Author
14 Mar 2012 21:59
#509700
Hey gang, My tank is in pretty good shape with just a couple of surface rust spots. What is the best way to clean out a rust free tank and prepare it for paint? There is some sediment in it so I need to flush it out but as long as I am at it...
Thanks,
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Re: Gas Tank prep for paint
14 Mar 2012 22:12
#509705
ThatGPzGuy wrote: Hey gang, My tank is in pretty good shape with just a couple of surface rust spots. What is the best way to clean out a rust free tank and prepare it for paint? There is some sediment in it so I need to flush it out but as long as I am at it...
Thanks,
Some folks opt to have the tank boiled out at a radiator shop.
Good Fortune! :)
  • ramtough_63
  • ramtough_63's Avatar
14 Mar 2012 22:24
#509708
radiator shop is your least expesive sure thing as they say
I have used alot of different things vinager, CLR, Kreem tank prep etc...
seems like I keep going back to CLR it's not too aggressive but does work if you have any real rust in it bypass the home remedies and use the radiator shop
Good ol SOap and water goes along way
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • ThatGPzGuy
15 Mar 2012 08:23
#509772
Thanks guys. I've used the radiator shop before for my H1 but I don't think this tank merits that kind of drastic action. It really is pretty clean and not rusty so I may just use warm soap water and then treat the inside to some W40. I am a little worried about any rust I can't see. Would CLR nuetralize that? I would hate to discover a rust problem after paint and graphics!
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
15 Mar 2012 09:01
#509774
  • ramtough_63
15 Mar 2012 10:33
#509793
ThatGPzGuy wrote: Thanks guys. I've used the radiator shop before for my H1 but I don't think this tank merits that kind of drastic action. It really is pretty clean and not rusty so I may just use warm soap water and then treat the inside to some W40. I am a little worried about any rust I can't see. Would CLR nuetralize that? I would hate to discover a rust problem after paint and graphics!
yeah I was/am sick over my tsnk i spent hours upon hours priming sanding painting sanding etc...on what looked like a good tank with minor scaling to find my paint bubling a week after I put it on and a full blown leak halfway through the season
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • ThatGPzGuy
22 Mar 2012 08:16
#511204
ramtough_63 wrote: yeah I was/am sick over my tsnk i spent hours upon hours priming sanding painting sanding etc...on what looked like a good tank with minor scaling to find my paint bubling a week after I put it on and a full blown leak halfway through the season
OK I'm sold. I dropped it off at the radiator shop on saturday. Also, I was looking at the tank and I noticed some bondo down by the seam. Better to be safe than sorry.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • gwolever
  • gwolever's Avatar
22 Mar 2012 23:24
#511373
I am wanting to do the same thing, but I can only find one shop in the general vicinity that does boil tanks. They want to charge $85 plus tax. Not gonna do it.
So I have a vinegar, evaporust, or CLR decision. I tried some vinegar in the tank after taping the petcock and fuel indicator holes in the bottom of the tank. That will not work as the vinegar leaked out almost immediately.
So which should I try next? If I try vinegar again, how the hell can I keep the vinegar in it?
If I go with the evaporust (saw some big jugs of it at Harbor Freight), do I need to neutralize afterward like vinegar?
How about CLR?
And what about flash rusting? I will be prepping and painting the tank after flushing out the rust inside. Are there any options that lessen the chance of flash rust? Or should I just spray some WD-40 in there when I'm done flushing the tank?
Don't mean to hijack the thread, but I figured since it is the same subject I wanted to ask about, why start a new one?
Thanks guys.
1982 KZ1000 CSR
  • ramtough_63
22 Mar 2012 23:49
#511378
gwolever wrote: I am wanting to do the same thing, but I can only find one shop in the general vicinity that does boil tanks. They want to charge $85 plus tax. Not gonna do it.
How about CLR?
Thanks guys.
you will need to make a blockoff plate or cap for the petcock hole. i used a piece of 1" flat aluminum and drilled the holes to match my PC. I dont know the correct size for the screw on PC but you can use a rubber plug to plug it or find a cap of some kind.
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • ThatGPzGuy
24 Mar 2012 11:39
#511642
My radiator shop charges that amount but it also includes the Red Kote. $85 is cheap insurance on a $300 gastank and a $1,000 paint job.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
24 Mar 2012 12:03
#511649
Have always successfully used muratic acid, but the Evaporust product sounds very promising.
Where lining is necessary, here are links to some more detailed info:
www.kzrider.com/forum/5-chassis/505764-red-stuff-in-tank#505777
www.cool-it.ca/Text/1268095710640-8086/p...68248377218-8881.pdf
Good Fortune! :)
  • gwolever
  • gwolever's Avatar
25 Mar 2012 23:08
#512003
Thanks for the info guys. I bought some flat metal pieces and cut them into block-off plates like you said ramtough. Drilled a couple holes in each one and screwed them right into tank with existing screws. Worked perfectly. My tank is now filled with vinegar and no leaks.
Thanks again guys.
1982 KZ1000 CSR
