leaky tank cure!
- steelhorseangel
- ad@wildlifeartist.plus.com
leaky tank cure!
03 Feb 2012 21:07
hi kzr's
time to give something back to everyone
on here!
my project bike is nearly finished. i plumbed
the tank in today. it was cleaned and internally
line with a product similar to kreem.
i can get 4 impressive white sparks
from the boyer bransden ignition, lets put gas
in i said. i discovered a pin hole leak that sprayed
gas everwhere. i disconnected and drained the tank.
looking on the web i surfed and discovered
'cures for pin hole leaks in gas tanks!'
1) jb weld gets melted by the gas
2) apoxy two parts doesn't work
3) weld - cabooom!......DON'T EVER
i've found a well tested product
called 'Petro Patch', do a search on the web.
i found mine on Amazon, it's really cheap and
actually stops gas tank leaks!
Pass the word around rider's!
i've bought mine today, repairing my leak
tomorrow!
Regards
Angel UK
ride, wrench and restore!
on here!
tomorrow!
Regards
Angel UK
Angel
Restore, Wrench & Ride!
Brought up with Dad, brother, all riders!
Our Dad (Eric) taught us both simple mechanics
before he went to the happy hunting ground, too soon (44)
My KZ is now called Eric and he will ride and protect me!
x God Bless x
x God Bless x
Last edit: 19 Feb 2013 13:09 by martin_csr.
- z1kzonly
Re: leaky tank cure!
03 Feb 2012 22:15
"Seal all" it is in a yellow tube $2.79. It looks like model glue.
Been around for 30 years. seals gas!
- z1kzonly
04 Feb 2012 01:03
- Topper
04 Feb 2012 01:55
Petrol Patch looks a lot like JB Stick (made by JB Weld). Anyone know if they're essentially the same thing?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- steelhorseangel
06 Feb 2012 21:15
hi kzr
i spent a few hours researching a cure for
pinholes in tanks.
1) jb weld products melt eventually
2) seal all - sometimes fails.
i used the petro patch and it does what
it says on the box. what you do is this:-
wear a mask and protective gloves.
do this patching outside, not enclosed.
don't breathe in the fumes or allow to
touch the skin.
clean the area around the pin hole and degrease it.
give the sealant a shake and using long nose
pliers dip in about an inch square patch, flatten it
on the pin hole.
allow this to set for 20 mins and then cut another
patch 1.5" and again dip it in the shaken liquid.
place over the first patch and again flatten.
allow to set for 24hrs and the leak has
been repaired.
jb weld melts with time!
regards
Angel
pinholes in tanks.
touch the skin.
on the pin hole.
been repaired.
regards
Angel
Angel
x God Bless x
x God Bless x
Re: Seal All - Low Fuel Switch leak repair
07 Feb 2012 09:52 - 20 Feb 2013 11:57Seal-All - Low Fuel Switch leak repair Seal All Seals All SealsAll Sealsz SealzAllz1kzonly wrote: "Seal all" it is in a yellow tube $2.79. It looks like model glue.
Been around for 30 years. seals gas! ---->>>>
Here it is!
eclecticproducts.com/sealall.htm
Seal-All Gas & Oil Resistant Adhesive
The web page has msds & tds links. Low Fuel Switch leak repair
Last edit: 20 Feb 2013 11:57 by martin_csr.
