Will a KZ 1000 tank fit on an LTD chassis?
- grubdog
26 Jan 2012 10:23
I want to buy an extra tank, and I was thinking of getting a KZ 1000 tank for my LTD. First, the bike is put together from parts, so it doesn't matter what identity it assumes. Second, I kind of like the look of a KZ tank; it appears to be larger than the LTD. The tank that I am looking at is from a 77, my frame is a 79 (I think).
- roy-b-boy-b
Re: Will a KZ 1000 tank fit on an LTD chassis?
26 Jan 2012 10:50
It will fit. Roy
The following user(s) said Thank You: grubdog, shap
- Mcdroid
- Gone Kwackers
26 Jan 2012 11:05
To expand on what Roy said, the two years tanks that will drop onto your frame are the 1977 and 1978 KZ1000A (standard) models. Be advised that when acquiring the petcock, the 1977 tank is a screw-on petcock, while the 1978 tank requires a bolt-on petcock.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- grubdog
26 Jan 2012 11:06
Sounds great! Plus, I have a screw on petcock; Pingle no less. Thanks for the clarification.
- mtkawboy
30 Jan 2012 15:17
Depending on your carbs you may need the Pingel offset adaptor for the 78 tank. Ive found that any 73-80 tank will interchange on any frame. There is no LTD specific frame, as far as tank fit goes until you get into the shaft drive ones which Im not sure of
The following user(s) said Thank You: shap
