Clearing my tank
  • dizl27
  • dizl27's Avatar Topic Author
Clearing my tank
13 Dec 2011 21:21
#493008
so i decided to paint my tank. I got the color on now. Which type of clear should i use to cover the paint? I need something strong that i might be able to wax right?
1977 650 Hardtail Bobber
1996 250 Yamaha Virago Bobber
  • DoubleDub
  • DoubleDub's Avatar
Re: Clearing my tank
13 Dec 2011 21:23
#493011
Wax isn't the issue, fuel is. It *has* to be a two-part clear coat with hardener.
  • dizl27
13 Dec 2011 21:28
#493012
yeah thats what i figured since gas took off the clear coat i originally had the tank painted.lol thanks
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
13 Dec 2011 21:28
#493013
DoubleDub wrote: Wax isn't the issue, fuel is. It *has* to be a two-part clear coat with hardener.
+1
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • DoubleDub
13 Dec 2011 22:15 - 14 Dec 2011 11:08
#493022
I used the Eastwood Eurethane Clear. Very happy so far.
www.eastwood.com/ew-urethane-clear-2-1-quart.html
Last edit: 14 Dec 2011 11:08 by DoubleDub. Reason: photo added
  • dizl27
14 Dec 2011 00:21
#493041
i was not planning on using HPLV. Is there a rattle can product i can use? Trying to keep this build budget down.
  • DoubleDub
14 Dec 2011 01:10
#493052
There is,, but I've never seen it in person or tried it. I did mine with a $15 harbor freight touch up gun and a borrowed compressor.
  • ramtough_63
  • ramtough_63's Avatar
14 Dec 2011 01:27
#493060
+1 on the harbor freight touchup gun. cant beat it the paint atomized great the larger gun not so much. the clear leavels beautifully with the smaller gun. onsale for like 15 bucks I have done 3 with the same gun bought the larger one now I just use it for primer,
spend a couple bucks on a cheap gun and good clear you will much happier when you are done.
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • DoubleDub
14 Dec 2011 10:09
#493089
ramtough_63 wrote: +1 on the harbor freight touchup gun. cant beat it the paint atomized great the larger gun not so much. the clear leavels beautifully with the smaller gun. onsale for like 15 bucks I have done 3 with the same gun bought the larger one now I just use it for primer,
Agreed.
OldManRock used a pump-sprayer. You could find his thread or PM him about it or maybe he'll post that info here, but I remember it costing more than the HF gun. The compressor I borrowed was only like an 8 gallon tank type. The touch up gun takes a lot less air than the bigger gun.
  • DoubleDub
14 Dec 2011 11:06
#493096
This is the gun I used (or very similar):
www.harborfreight.com/touch-up-air-spray-gun-66871.html
This is the compressor I used (or very similar):
www.harborfreight.com/2-hp-8-gallon-125-...ompressor-67501.html
There are constantly 20% off coupons available for Harbor Freight also...
I found this gun also, which might even be better since it is gravity/suction fed rather than just suction (less air flow required I believe):
www.harborfreight.com/adjustable-detail-spray-gun-92126.html
  • DoubleDub
14 Dec 2011 11:07
#493097
Yep, 3CFM rating for the pink gun, 4.7CFM for the one I used. But I can only vouch for the silver one, personally.
  • DoubleDub
14 Dec 2011 11:10
#493098
I also want to add that a friend of mine went the spray can route (a product from Eastwood) and it didn't turn out nearly as well as the two-part that I sprayed. It has a dull finish to it that doesn't look like a nice clear coat.
I can't say if it was the product, the paint he used, or the person - I didn't help him apply it.
I think others on here have used a different spray can product and had good luck with it, I don't remember what it was called and remember it being very hard to find.
