would this be safe??
  • jamestheron
  • jamestheron's Avatar Topic Author
22 May 2006 16:02
#49204
im looking at a custom rear fender but the rear bar frame (fender mount) is in the way do you think it would be ok to cut the frame inch or two past the shocks and reweld tubing closer the the seat
  • jamestheron
Re: would this be safe??
22 May 2006 16:03
#49205
i borrowed the pic you can see the bar going over the rear fender
  • The Milkman
  • The Milkman's Avatar
22 May 2006 17:11
#49232
If it was me, I would make a solid clamp type brace to go across in front of where you are going to cut it to hold the frame in place, just as a precautionary measure.
  • jamestheron
22 May 2006 18:06
#49250
oh definitely ill just weld a brace first then Fabe it up and then cut the brace off i think it will work i just want to hear your takes on the idea
Post edited by: jamestheron, at: 2006/05/22 21:07
