Help removing old brake fuild from the frame
- bluej58
28 Nov 2011 22:29
Please tell me how you would approach removing twenty year old brake fluid .
I was thinking about starting with brake cleaner, yes?
I want to paint the bad spots with Rustolyum.
Thank you
JD
Thank you
JD
78 KZ1000 A2A
- silentchris
Re: Help removing old brake fuild from the frame
28 Nov 2011 23:30
Brake clean a rag and elbow grease just dont spray and plastic parts
Speed is only a question of money. How fast do you wanna go?
1978 kz1000 ltd
Hailing from the wild suburbs of our nations capital
1978 kz1000 ltd
- bluej58
16 Dec 2011 02:08 - 16 Dec 2011 02:09
I can't believe how filthy this bike is.
Every nut and bolt is coming off.
I have been finding that engine degreaser and a tooth brush is a good start on some of the nastier spots,followed up by the brake cleaner and a tooth brush again and more brake cleaner, then wipe it off.
At this point I have been taking a wire brush to it, look at all the rust :pinch:
I'm also using a good cordless drill with a bunch of different size wire wheels and getting everything.
Using the reverse on the drill is turning out to be very helpful.
everything gets a final wipe down with acetone and then I'm brushing Rust-oleum (rusty metal)primer on the bare metal in an effort to work it in better, and following up with spray primer from a can.
78 KZ1000 A2A
Last edit: 16 Dec 2011 02:09 by bluej58.
