how to make my motor look like that KZR bike at the top
- dan76kz900
18 May 2006 19:59
I am planning on painting my motor soon. I am going to do gloss black engien paint. My plan is to take the aluminum covers off and polish them, and then paint the case and clyinder head black.
I have been admiring the looks of that motor on that Z on KZR's webpage up at the top. I want to make mine look like that one
How do I make my fins like that ? Ive heard of block sanding the fins - is that what they did on that motor ? The edges look thick - did they sand alot down ?
Also, I've been thinking of finding some chrome engien bolts - my stainless steel ones arent looking that great. Any ideas ?
- Pterosaur
Re: how to make my motor look like that KZR bike at the top
18 May 2006 20:15
dan76kz900 wrote:
That's exactly how it's done - start with 220 wet on a block. How much you take off is up to you - you can give it a "fine line" look, or sand 'em back to their full thickness. Once you get to the desired line thickness, go to 400, then 600, then 1000 grit papers - then finish with Simichrome or Blue Magic or whatever polish makes you happy...
The finish on the '73 Z1 inner cases, jugs, heads and valve cover wasn't gloss - it was satin-flat. PJ's sells a hi-temp rattlecan version. And once you paint 'em - BAKE 'EM at 200-250' in an oven for at least an hour - sets the paint and gets rid of girlfriends, groupies and wives in a big hurry as a side benefit... :sick:
...How do I make my fins like that ? Ive heard of block sanding the fins - is that what they did on that motor ? The edges look thick - did they sand alot down ?
- wireman
18 May 2006 20:22
you might want to start with a coarse double cut file and get things roughed into shape before you start blocksanding.:whistle:
- Pterosaur
18 May 2006 23:57
wireman wrote:
That's true, you can, but using *that* kind of artillery, you can get into "oops" territory pretty quickly. Especially if swinging a double-cut ain't part of your everyday existence. Everybody's mileage varies...
- Mark Wing
19 May 2006 00:10
I did my covers with metal polish and a buffing wheel on a bench grinder. I painter my jugs and cases simi-gloss black and did the fins by hand starting with 80 grit then i50.
Mark
Post edited by: Mark Wing, at: 2006/05/19 03:21
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- dan76kz900
19 May 2006 07:16
Oh, so they did sand down alot on that motor in the picture. Hmm.. maybe I'll do it. My idea was to paint first then sand.
Mark: Looks good ! I plan to sand my covers 400, 800, 1500 then hit it on the buffing wheels with tripoli then rogue compound
Any idea for the bolts, anyone ??
- Pterosaur
19 May 2006 07:27
dan76kz900 wrote:
That's how it's done - paint first. Saves a couple of steps...
Keep an eye on Ebay - there's generally a set of some type of gizmo bolt set listed - and there's always the usual Z1 Enterprises, Ron Ayers, etc...
- wireman
19 May 2006 07:49
id get them close first before you paint them,then fine tune afterwards that way you dont have to worry so much about banging up the paint.
- Robjb84
10 Jan 2007 09:34
Sorry to dig up such an ancient thread, but is it at all feasable to hand paint (with a brush) the fins?
Or does the whole thing really need to be taken apart and sprayed? Or perhaps everything else on the bike can be masked up/covered and spray them with the bike on the centerstand?
Sorry, I am fully aware that I am a noob with this kind of thing. Just love the black fin look
- Pterosaur
10 Jan 2007 10:01
Robjb84 wrote:
Strictly speaking, sure you can - but one thing to keep in mind is whether the results will be worth it. When it comes to appearance, there's no such thing as a free lunch, and 5 minute shortcuts invariably come out looking worth just about every minute spent in prep/application.
I can think of about a dozen ways to shortcut the process, and a couple of dozen reasons why even if it was done by someone of even moderate experience, it'd start looking like hell in a hurry.
There's sure to be at least half a dozen shorcuts suggested, some of which are even do-able, and even somewhat effective in the short term - but there's reasons why they're shortcuts to begin with.
The biggest problem here is metal prep - aluminum is dodgy enough to get paint to stick to when properly prepped - just slathering it on with a brush is asking to see strips of your new paint peel off in the next breeze.
Learn to do it right, and the reasonable shortcuts become obvious.
No problem there; everybody starts out like that - but just like decent paint jobs, there's very few *valid* shortcuts to experience.
Sorry to dig up such an ancient thread, but is it at all feasable to hand paint (with a brush) the fins?Or does the whole thing really need to be taken apart and sprayed? Or perhaps everything else on the bike can be masked up/covered and spray them with the bike on the centerstand?
- Robjb84
10 Jan 2007 10:07
Well in that case do I somehow need to get the engine out of the frame
and I assume I can pull apart the particular fin section?
I guess my worst fear is attempting something like that and unknowingly ruining something
- ltdrider
10 Jan 2007 10:11
I came across a polishing product called Mr. Buffer. I found it on a Voyager site, and they all swear by it. These Voyager people are SERIOUS engine polishers, and they claim great results with Mr. Buffer.
I couldn't find it in my area, so I ordered a bottle ($12.99 plus shipping) from their web page.
I'm told that if you start with a smooth aluminum surface, that it'll take it to a mirror finish faster than anything. And it leaves some kind of protective coating so it stays shiny.
Here's the link:
www.mrbuffer.com/
Anyone ever try this stuff?
Here's the link:
www.mrbuffer.com/
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
