1982 KZ1000 LTD modification
- Observer
23 Sep 2011 09:31
New to the forum & need assistance
I would like to mount a tailfin (kz10000 or 900 style) on my 1982 KZ ltd anyone with
advice on the best approach?
Cheers
Cheers
- jonnybravo
- Banned
Re: 1982 KZ1000 LTD modification
23 Sep 2011 10:11
welcome
n ot familiar with the 82 frame , however, if it doesnt match for mounting purposes i would get a cheap repo tailpiece off the net, do a little fiberglass work to it to make it fit, find a how to fiberglass on the net on go to it
- cobura
- forever 2 wheels
23 Sep 2011 10:36
Another idea if you can weld, I would just weld a few nuts onto the frame where the tailfin bolts in.
1979 KZ650B3
23 Sep 2011 11:58 - 12 Oct 2011 10:21
the way the subframe and seat is stepped is going to cause you problems.
i have been trying to get someone to cut off the rear sub frame and fab a new one so they could put kz/z1 sidecovers tail piece and flat seat pan.
but if you are not comfortable cutting the rear of your frame off and welding a new sub frame on there is not much option.
there isn't any "cool" tailpiece that just bolts on the 81 and later ltd's.
check out marnemans project thread he cut the rear and added a kz650 tail and cut his pan
and used a zrx seat cover.
Last edit: 12 Oct 2011 10:21 by 531blackbanshee.
- Observer
23 Sep 2011 20:59531blackbanshee wrote: the way the subframe and seat is stepped is going to cause you problems.
there isn't any "cool" tailpiece that just bolts on the 80 and later ltd's.
Thanks very much. Not sure I want to cut the frame though. I'll give it some thought
- purple_haze
12 Oct 2011 03:33
leon the 80 LTDs have the cool tailfin, its 81 when they went to J model that it changed
the trouble with you is the trouble with me, you got two good eyes but still dont see...
jerry
jerry
12 Oct 2011 10:28
corrected thanks purple haze.
