Rear Wheel Play
- grumpy56
Rear Wheel Play
04 Sep 2011 10:50
I have a bit (almost impercetible but there) of side-to-side play in the rear wheel of my KZ1000J2. Any ideas as to cause and if I need to worry about it? Thanks.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- indianajames
Re: Rear Wheel Play
04 Sep 2011 18:39
hey grumpy , is the play at the axle or swing arm pivot ? if it the axle , maybe some bearings would fix it. i had some side to side play at the swing arm pivot ,about a 16th of an inch, even with the swing arm pivot bolt torqued to spec. i took the swing arm pivot bolt out far enough to put in a copper washer between the frame and the swing arm cap and torqued to spec . seemed to fix mine perfectly , zero play and the copper washer is softer than the parts its between. my bike is an 82 750, hope this helps.
- MFolks
Re: Rear Wheel Play
04 Sep 2011 18:57
I'd pull the rear wheel and see if the rubber "Cush" drive is coming apart. They can go bad, making you think a bearing is going out or swingarm problems.
- grumpy56
Re: Rear Wheel Play
05 Sep 2011 00:28
Thank you guys. It appears to be at the axle and everything seemed to be OK about 3K miles ago when I changed the rear tire. Not sure if this condition was present then or not. Will take it apart and check it out.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
