Removing factory black engine paint?
  • jydog
  • jydog's Avatar Topic Author
04 Sep 2011 09:11
#474131
Anyone know an easy way to remove the the factory blak engine paint that comes on GPz motors etc..
I like the silver or polished finish much better. Might be easier to sell or trade for the silver parts?
81 KZ1000 LTD
Griffin GA
  • gengomerpyle
  • gengomerpyle's Avatar
Re: Removing factory black engine paint?
04 Sep 2011 09:24
#474136
blast it off
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • martin_csr
  • martin_csr's Avatar
Re: .
04 Sep 2011 09:25 - 22 Jan 2013 04:32
#474137
Last edit: 22 Jan 2013 04:32 by martin_csr.
  • gengomerpyle
04 Sep 2011 09:33 - 04 Sep 2011 09:34
#474138
baking soda
martin_csr wrote: I don't know much about it, but... I don't believe it's a good idea to sand blast it.
1982 GPZ750R1 ELR
1971 Honda CB750K
Last edit: 04 Sep 2011 09:34 by gengomerpyle.
  • indianajames
  • indianajames's Avatar
04 Sep 2011 09:39
#474140
hey jydog , if the engine is out of frame or your gonna repaint frame this is how i do it . spray stripper in can, start at the top . wrap coils and wiring with foil . get some brass brushes , the ones about the size of tooth brushes . use old sray bottle with water to rinse as you move down the engine . dont try to get everything at once . make a couple passes , then when most paint is gone spray it down with aluminium wheel cleaner and rinse with water hose or power washer. sounds like alot of work but its not to bad , i have done this in one day with great results , just wrap up any thing you dont want stripper on , good and tight with foil , its cheap insurance from the dollar store.
  • indianajames
04 Sep 2011 09:44
#474141
yea might be easier to sell or trade , is there silver factory gpz parts?
  • jydog
04 Sep 2011 11:44
#474157
Yeah, it is all apart. I am definitely keeping the head and cams but the cases are the same as a J motor I believe. Funny thing is I have two of them. 81 and an 84. So if anyone is going black on a J motor hit me up I've got a factory black one and one that was just freshly painted.
81 KZ1000 LTD
Griffin GA
