tricks for gas cap?
  • xbmxxx
  • xbmxxx's Avatar Topic Author
tricks for gas cap?
23 Aug 2011 23:35
#471325
I have the original 76 KZ750 fuel tank on my bike. The open/close lock works, but after I close it and lock it, after about a mile of riding the vibration has unlocked it and it bounces like crazy. Has anyone else had this problem and if so what did you do to fix it?
76 KZ750B Twin
  • jeffasaki
  • jeffasaki's Avatar
Re: tricks for gas cap?
24 Aug 2011 01:03
#471361
had this problem
took the cap completely off the tank
took a good look at it
found it oxidized with a broken spring
took it apart cleaned and oiled it
put in a new spring
used a toilet gasket from home hardware (had to cut ID to correct size)
for a new cap gasket
never happened again
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
