How to identify key number?
- Kapahulu
02 Aug 2011 21:40 - 05 Aug 2011 17:31
I just bought this 1976 KZ900. It has one key, a duplicate. I pulled the ignition switch out of its housing looking for a key code number and didn't find one. Did I not look in the right place?
The bike doesn't have a seat lock and I want to get one for it.
Thanks, Mike
Thanks, Mike
2strokeworld.com
2strokeworld.com
Last edit: 05 Aug 2011 17:31 by Kapahulu. Reason: typo
- Gman
Re: How to identify key number?
03 Aug 2011 18:54
There should be a code stamped on the side of the ign lock casing. If it still has the steering lock, there should be a code stamped on the face of it. You don't have to remove it to see it. Difficult to look at it from underneath though. But there is no such thing as a '79 KZ900. 1976 was the only year for the KZ900.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
2002 Gold Wing
1974 Z1 900 project
- rstnick
04 Aug 2011 23:46 - 04 Aug 2011 23:49
The key code # will be located in different spots throughout the years.
On my '78 it was right beside the keyhole on the ignition, as it is on most early, Zs/KZs.
In '79 it was beside the seat lock's keyhole.
On others it may be on the side or back of either lock.
It will be in one of the series listed below.
Any other number is probably just a cast in part # or something.
Kawasaki Key codes:
170-174
175-195
176K-250K
251K-325K
3101-3150
3201-3250
326K-400K
401-470
701-720
706-710
751-795
8001-9000
801-845
901-925
A00-A99
B8001-B9000
E8001-E9000
G1-G35
KZ5001-KZ6000
N1-N35
RVS101-RVS499
Z5001-Z6000
Kawasaki Key codes:
170-174
175-195
176K-250K
251K-325K
3101-3150
3201-3250
326K-400K
401-470
701-720
706-710
751-795
8001-9000
801-845
901-925
A00-A99
B8001-B9000
E8001-E9000
G1-G35
KZ5001-KZ6000
N1-N35
RVS101-RVS499
Z5001-Z6000
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 04 Aug 2011 23:49 by rstnick.
- Kapahulu
05 Aug 2011 17:34Thanks, that was a typo. It's a 1976 KZ900. I guess I got mixed up because I also have 1979 KZ1000.Gman wrote: There should be a code stamped on the side of the ign lock casing. If it still has the steering lock, there should be a code stamped on the face of it. You don't have to remove it to see it. Difficult to look at it from underneath though. But there is no such thing as a '79 KZ900. 1976 was the only year for the KZ900.
Anyways, on the KZ900, the seat lock is gone and I don't see a steering lock! Puzzling, I figure they must have had one originally.
I removed the ignition switch completely, cleaned the grime off it and didn't see any numbers. I guess I'll look again!
2strokeworld.com
2strokeworld.com
- Kapahulu
07 Aug 2011 18:15
I went and looked at the ignition switch again, found the key number. Thanks for your help! Now to locate a seat lock with the same key #.
2strokeworld.com
2strokeworld.com
