treating rust on exhaust pipe
  • wdizard
  • wdizard's Avatar Topic Author
27 Jul 2011 13:11
#465286
Is there any thing you can apply to a chrome exhaust that is starting to rust? I was thing of applying wd40 to the surfaces during the winter when I am not able to ride. But I am not sure how to remove wd40 when the winter is over, Any ideas out there?
thanks Greg:)
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
Re: treating rust on exhaust pipe
27 Jul 2011 14:46
#465321
WD40 evaporates and really isn't any good at preventing rust anyway. Get you some Nevrdull www.nevrdull.com/ It removes light rust. But if it's fairly heavy rust, rub it off with fine steel wool, then polish it with the Neverdull. And when you know you're done for the season, rub the Neverdull on, but don't polish it off. Much better than WD40.
The following user(s) said Thank You: wdizard
  • Chaotic Reason
  • Chaotic Reason's Avatar
27 Jul 2011 15:00
#465325
Have you tried Brasso? Same technique as mentioned above.
Michael
1980 KZ1000 shaft drive
  • hocbj23
  • hocbj23's Avatar
27 Jul 2011 21:42
#465399
white diamonds metal polish and a slow speed buffing wheel work wonders on litely pitted chrome and aluminum--plus it works as a coating as well preventing re-rusting.bj
  • martin_csr
  • martin_csr's Avatar
Re: -
28 Jul 2011 09:12 - 15 Feb 2013 11:03
#465490
Last edit: 15 Feb 2013 11:03 by martin_csr.
28 Jul 2011 09:29 - 28 Jul 2011 09:33
#465491
To remove rust I have found Birchwood Casey Blue & Rust Remover to be the absolute best (see link for pic). Any decent gun shop should carry it. Unlike Brasso etc. it is non-abrasive so you won't end up removing chrome. It's not fast; you need to soak the rust area for a couple hours. If you're storing a part for the winter you can just give it a good coating of Vaseline to shield it from moisture. It will wipe off easily in the Spring.
www.cabelas.com/solvents-lubes-bluing-bi...rust-remover-2.shtml
Last edit: 28 Jul 2011 09:33 by 650ed.
  • Bigberst89
  • Bigberst89's Avatar
20 Sep 2011 22:38
#478165
I have a spectre with the black exaust pipes, is there any way to get the rust off?
1982 Kawasaki Spectre 1100-D1
20 Sep 2011 22:45
#478167
  • Chaotic Reason
20 Sep 2011 23:22
#478174
@Bigberst89-- The black exhaust, is it ceramic coated, is it bbq paint, is it really high heat over chrome? How rusted is it? Does it go all the way through? Is it light and just slightly pitting? Some pics might make it a bit easier to suggest something...
Michael
21 Sep 2011 00:07
#478180
Bigberst89 wrote: I have a spectre with the black exaust pipes, is there any way to get the rust off?
Here's some information about black chrome.
webcache.googleusercontent.com/search?q=...&hl=en&ct=clnk&gl=us
Black Chrome Plating:
Black chrome is usually plated over bright nickel or matte nickel in the same manner as decorative chrome. Black chrome is not quite as hard or wear resistant as normal nickel/chrome and it is not lustrous. The finish may waxed or oiled to improve the final appearance.
www.finishing.com/faqs/chrome.html
www.ehow.com/way_7217159_repair-removal-black-chrome.html
How bad is the rust?
Other options could be ceramic coating or spraying with hi-temp black paint.
Good Fortune! :)
  • wireman
  • wireman's Avatar
21 Sep 2011 06:27
#478219
glass bead them and repaint B)
  • wireman
  • wireman's Avatar
21 Sep 2011 06:34
#478220
i had an old guy tell me years ago the best low buck
way to polish copper radiators was with ketchup because of the acid in it ,i thought he was crazy till i actually tried it.
it really works! :laugh:
Attachment heinz.jpg not found
