77 kz1000 what kind of paint for frame/batterybox?
  • wdizard
  • wdizard's Avatar Topic Author
24 Jul 2011 21:15
#464663
I want to touch up the paint on my frame, the color is black, Does any one know what kind of paint works best?
Thank you,greg
  • hocbj23
  • hocbj23's Avatar
Re: 77 kz1000 what kind of paint for frame/batterybox?
24 Jul 2011 22:39
#464684
Unless frame has been powdercoated, most any gloss black will work. I use black caliper paint as it is both gloss and heat resistant plus u can brush it on.. good luck.bj
  • wdizard
25 Jul 2011 00:03
#464707
Do you know whwere to get this?
Greg:)
  • Gman
  • Gman's Avatar
31 Jul 2011 09:17
#465984
Greg,
I've had good luck with Rustoleum 7779 Gloss Black. The code is on the can right above the bar code. It is a very close match to the Z1 and KZ factory paint on the frames. I buy it at my local True Value harware store. Should be readily available at many stores.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
The following user(s) said Thank You: wdizard
