baking paint in the oven
  • Tested
  • Tested's Avatar Topic Author
24 Jul 2011 00:01
#464540
Does this help it adhere and harden? Im think of cooking my clearcoat on my tank at 350 after i paint it.
2008 KLR 650
1977 KZ 750
_____ Have had _____
1981 KZ 440
1970's CR 125
1982 KLX 175
  • ravenz07
  • ravenz07's Avatar
Re: baking paint in the oven
24 Jul 2011 00:37
#464546
I would think 350 would be too high. Maybe somewhere along the lines of 150-200. Supposedly it helps to make things more durable but the main thing about baking is that instead of waiting a month to wax and polish the paint, you can do it after a few days.
1994 Kawasaki KZ1000 Police
1980 Kawasaki KZ750 LTD
1981 Yamaha XJ650H Maxim
  • MFolks
  • MFolks's Avatar
24 Jul 2011 00:51
#464548
I've never baked a gas tank, but plenty of brackets,mounts & other metal parts. They will produce a ""Smell" at 350 F, just have the windows open afterwards to air the house out.
It hardens up the paint, so after cooling they can be installed on the bike.
  • Tested
24 Jul 2011 02:50
#464559
Right on. Thanks guys. I will aim for 175 for what like 20 mins?
Yea I'm think doing the gas tank might be a bad idea. I will stick with all the brackets and assorted small stuff I am doing. Think I will create some kind of rack that will fit in my home oven.
2008 KLR 650
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
  • ravenz07
  • ravenz07's Avatar
24 Jul 2011 03:26
#464562
What I found is "About 140ºF for 5 or 6 hours seemed to work OK. It will really stink up the house at first as it degasses so open your windows if possible...."
  • martin_csr
  • martin_csr's Avatar
Re: -
24 Jul 2011 09:57 - 15 Feb 2013 11:25
#464577
Last edit: 15 Feb 2013 11:25 by martin_csr.
  • otakar
  • otakar's Avatar
24 Jul 2011 10:54
#464581
140F is about MAX you want to heat the paint up to. Much more than that you will be looking at one big blister or many small ones. Baking paint is only as a last resort. Natural cure is always the best way to go.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • flhwesty
  • flhwesty's Avatar
24 Jul 2011 15:51
#464626
Read the spec/product information sheet on the paint. I work in a paint shop (kitchen cabinet/wood/furniture). Our product calls for 50C for 30 minutes. It also has a varialble time, like 40C for 45 minutes...
350F sounds a little high.
The product info sheet will answer this question.
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1981 GPz1100 KZ1100-B1
  • Kapahulu
  • Kapahulu's Avatar
24 Jul 2011 18:49
#464644
Baking also smooths out the paint, making for a nicer finish. I do that a lot on small parts. Don't do it with plastic.
2strokeworld.com
