Spraymax 2 part clear coat question
- Topper
23 Jul 2011 11:21
I just laid a few coats of Spraymax 2k clear coat on my tank and side covers.
I can't find any info on either the can or the Spraymax website about wait time before sanding and polishing.
If it were a standard rattle can clear I'd wait a week to let it cure. Do I need to do that with the 2k clear?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- Old Man Rock
Re: Spraymax 2 part clear coat question
23 Jul 2011 11:50
Can't speak of this particular product but most 2 - 3 part clears w/hardner/accelerator what ever only require ~ 24 hours cure time...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
23 Jul 2011 11:59
sorry Rock, I beg to differ. Urethane paints cure (and shrink) for as much as 90 days. This is why all of the sudden after a few months of having a beautiful water like paint job you can notice orange peal. First of all I have no idea how you get a two part urethane in a rattlecan, but I have gone threw gallons and gallons of two part paints om everything from Aircraft to bikes. I would however have no idea on rattlecan full cure. All I have ever used those for was to touch up rivet heads and screw heads.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
23 Jul 2011 12:07
Otto, was speaking of clear part only, not paint for different story/concept entirely...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Topper
23 Jul 2011 17:18
Well that's clear as mud
Sounds like 24 hours should be sufficient. Thanks!
1979 KZ750 Twin
1979 KZ750 Twin
- otakar
23 Jul 2011 18:44
I thought that WAS what we were discussing, Clear. ???? But still I have no idea on how you can have a two part of any kind in a spray can.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Proxy
- 80% Human 20% Nuts/Bolts
23 Jul 2011 19:20
It has an internal bladder in the can. You push a button on the bottom of the can and puncture the bladder adding the catalyst. It's pretty hard to push the button but you know it when you do. You then have something like 24 hrs to use it. It's pretty neat. I have yet to see if it stands up to gas but it does advertise that it stands up to most solvents.
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- otakar
23 Jul 2011 19:40
I guess that's a real two part clear in a can. That is truly ingenious.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 15 Feb 2013 11:25 by martin_csr.
- otakar
23 Jul 2011 22:08
Yes Urethane paints are intended to be sanded and polished. I normally apply 2-3 coats about 45 minutes apart than i allow to harden for seven days and than I do my first sanding and polishing. First I sand with 420 extremely lightly than I sand with 600 till no glossy is visible than I sand with 1200 and finally with 3000. Finally I polish. After 90 days if I see ANY orange peal I sand again with 600 than 1200 than 3000 and polish again. I normally apply 3-4 coats of clear. When sanding you MUST stay away from any edges or you will sand threw the clear.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
23 Jul 2011 23:17
The hardness of the Urethane is Much Much harder than Lacquer. If you don't sand it within the first seven days you will be sanding for ever. The stuff is that hard. It keeps on hardening for about 90 days.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
