Gas Tank Removal
  • sevenfiftyman
  • sevenfiftyman's Avatar Topic Author
Gas Tank Removal
15 Jul 2011 15:23
#463023
Hey everybody. Looking for some tips on how to remove the gas tank on an 82 KZ750E-3. Would like to know how to remove the tank, as well as drain gas lines so i don't make a mess. Thanks.
  • martin_csr
  • martin_csr's Avatar
Re: -
15 Jul 2011 18:13 - 15 Feb 2013 11:05
#463036
Last edit: 15 Feb 2013 11:05 by martin_csr.
Re: Gas Tank Removal
15 Jul 2011 18:28 - 15 Jul 2011 18:30
#463038
I haven't done your model, but the drawing looks like you just open the seat, remove the bolt at the rear base of the tank and pull it up and back off the dampers. First shut off the petcock - (YOUR PETCOCK MAY NOT HAVE AN OFF POSITION so follow other's advice on this part) and remove the fuel line and disconnect the fuel gauge connector. As long as the petcock doesn't leak if you remove the fuel line from the petcock there shouldn't be more than a couple drops of fuel dripping out. But wear safety goggles if you're not sure about the condition of the petcock. You could also use a piece of clear tubing to syphon most of the fuel out of the tank first if you want. Ed
Last edit: 15 Jul 2011 18:30 by 650ed.
  • sevenfiftyman
01 Aug 2011 14:18
#466180
Thanks guys, really appreciate it.
