1980 kz550 ltd fuel tank alternatives help
  • baddogdaddy
  • baddogdaddy's Avatar Topic Author
27 Jun 2011 02:43
#459609
Hey all, I just joined up the other day when I got my hands on an 80 kz550 ltd. I have a tank leak that alerted me to the fact that there's about a gallon of bondo under the paint. I'm sad to say that the tank is trash. I don't want to spend 700 on a nos tank that I'm not fond of the style of. Im hoping that you all could point me in the right direction for an aftermarket tank or give me an idea of what other years or models are compatible. Also if anyone knows a source for headers I'd appreciate that as well. Thanks in advance!
1980 kz550 ltd
  • martin_csr
  • martin_csr's Avatar
Re: -
27 Jun 2011 10:02 - 15 Feb 2013 10:37
#459645
Last edit: 15 Feb 2013 10:37 by martin_csr.
  • Ixer
  • Ixer's Avatar
Re: 1980 kz550 ltd fuel tank alternatives help
27 Jun 2011 15:52
#459720
1. Strip all the existing paint and filler out
2. Apply JB Weld (with a body filler spreader) and get as smooth as you can
3. Use a grinder or sandpaper to smooth everything back out
4. Apply body filler sparingly to smooth out the metal surfaces
5. Primer
6. Paint
jbweld.net/products/uses.php#jbweld
www.kreem.com/fueltankliner.html
THe Kreem is probably overkill but better safe then sorry, plus it cleaned all the residual rust out of the tank.
All in all it cost less then $50 to repair my tank.
'82 KZ550 A3 - First bike, Attempting to put it back together after sitting for the last 12 or so years.
