ABS Fender Painting?
- KitNYC
08 May 2006 09:55
Hey paint gurus:
Apologies for the non-KZ question. I have a brand-new fender for my Triumph. $160 item I scored for $40 shipped on eBay! Of course, it's red instead of black, & nowhere near the same red as the trim on my bike...
After getting quoted $100 to paint it at a couple different places, I've decided that a rattlecan job is called for. I'd like to do it right, so I'm looking for tips.
I figure I'll sand it first, but I'm not sure what grit to use.
After sanding, I figure I'll hit it with paint & a clear coat. I'm looking for brand & product recommendations here, the fender is made of ABS plastic.
Also, do I need a primer?
Thanks,
-Kit
Thanks,
-Kit
- dan76kz900
Re: ABS Fender Painting?
08 May 2006 16:50
I'm not a paint gru, but this is what I think..
since its ABS, you dont need any special paint. Well, I would use a grey scotchbrite pad to scratch the fender up for painting. Do not scuff it too aggressively, or scratches may be seen though the paint. Since you are gonna spray bomb it.. I dont think you need to bother with a primer or sealer. Are you going to spray it black ?
- KitNYC
08 May 2006 16:59
Thanks, Dan. I've never seen a grey Scotchbrite before, but I'll have a look when I'm at Lowe's or Home Depot or whatever.
I am going to spray it black.
Cheers,
-Kit
Cheers,
-Kit
- dan76kz900
09 May 2006 17:37
I dont know if those home improvment stores will have the grey scotchbrite. I'd try a auto parts store - they probably small packages of them.. A paint supplier shop probably would only sell you a box of them.
- KitNYC
10 May 2006 10:28
Thanks. I'll take the local roads home from my girlfriend's place today & stop in one of the auto parts shops along the way.
Cheers,
-Kit
Cheers,
-Kit
- rammy
10 May 2006 10:49
depending on how much the fender is going to flex if any you might want to see about getting paint with a flex agent in it.regular laquir or enamal paint may be too "stiff"and crack since you will be painting ABS / plastic
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
- Pterosaur
10 May 2006 11:29
rammy wrote:
Agreed.
ABS is funny stuff. There's special mold release treatments to get 'em squeaky clean while prepping - you might think it's clean, but even traces of the mold release will cause enough "fisheye" to make the fender look like a map of the moon. Flex agents to allow the paint to stretch and bend with the fender.
Here's a good site on problems with ABS painting:
www.umgabs.co.jp/en/solution/trouble/t_50.htm
Might sound like a lot, but depending on the job, $100 isn't out of line. Especially if it's guaranteed.
Best of luck with it....
Agreed.
- FireBurst
10 May 2006 11:30
Just find an autobody supply store. They should be able to mix the paint the exact color you need and load it into a rattlecan. They will also know what prep is required for the product you are using.
- KitNYC
18 May 2006 00:10
Thanks for the tips, y'all. I ended up fiberglassing my cracked fender into workable shape & selling the brand-new, factory painted red one. I've been out of work for a while, so a little extra cash makes up for riding around with a ratty fender 'til I'm employed again.
Cheers,
-Kit
Cheers,
-Kit
