Repairing cast aluminum
- Archiddeon
17 Jun 2011 18:16
I just removed the handlebar throttle housing on my '83 GPz550. I'd noticed that it was cracked before (see first photo), but the repair job is, how to put this politely, less than satisfactory. Seems that filling the housing with some sort of filler, bondo perhaps, was the best the guy could do (see second photo).
So, I'd like to do it properly. The housing appears to be cast aluminum (where the paint has chipped off it has exposed a dull grey material, can someone confirm that this is what these parts are made of, or are they some sort of high density plastic?) and I've seen online that such items can be "easily" repaired with an aluminum brazing rod and a blowtorch. As it's not a high stress part, would this technique work well?
Also, what is supposed to go in space currently filled in? Some sort of metal bracket to hold the handlebar, or just empty?
Thanks!
Thanks!
1983 GPz 550
1985 Honda CH150 Scooter
1995 Suzuki GS500E
1995 Suzuki GS500E
- btchalice
Re: Repairing cast aluminum
17 Jun 2011 18:41 - 17 Jun 2011 18:41
that repair is the dreaded JB weld but i would just replace it there should be a lot of them out there semi cheap
it could be tig welded if you have a friend with a welder
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
Last edit: 17 Jun 2011 18:41 by btchalice.
The following user(s) said Thank You: Archiddeon
- testarossa
17 Jun 2011 18:55
Not sure if it's cast aluminum or not. A lot of the cast alloy parts on these bikes are zinc. In any case, I like btchalice's idea. Put a want add in the for sale section. There are a few gpz owners here. Or start searching ebay.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- Archiddeon
17 Jun 2011 19:31
Yeah, been trying to chip out the JB weld ... it's nasty stuff! Any easy-ish ways to get rid of it? solvent perhaps?
Thinking of replacing the assembly, couple of international (UK and Oz) sellers on ebay for ~$40 ... OEM replacement from Kawasaki is only ~$80. Going to post in the wanted section of the forum
Thanks!
Thanks!
1983 GPz 550
1995 Suzuki GS500E
1995 Suzuki GS500E
17 Jun 2011 19:51
Just replace it. Here's 1 used and 1 NOS:
cgi.ebay.com/ebaymotors/1984-KZ-550-H-GP...fPartsQ5fAccessories
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...3D719566768936504537
- Archiddeon
17 Jun 2011 20:08
Wow, nice
I found one for $25 from an '89.
Contacted the used one's seller to see what the condition is
Maybe off topic, but what does the "nos" mean? Clearly not nitrous oxide NOS
1983 GPz 550
1995 Suzuki GS500E
1995 Suzuki GS500E
- hocbj23
17 Jun 2011 21:59Archiddeon wrote: Wow, niceI found one for $25 from an '89.Contacted the used one's seller to see what the condition is
NOS = New Old Stock
But now I'm confused. I thought you were looking for the throttle control for a '83 GPz550. That is part number 46091-1207. That part was used on the following bikes:
Model (5):
KZ550-H1 (GPz) (1982)
KZ550-H2 (GPz) (1983)
ZX550-A1 (GPz) (1984)
ZX550-A2 (GPz) (1985)
ZX550-A3 (GPz) (1986)
It wasn't used on an '89 anything. Are you modifying the bike just because of a cracked housing? Why pay $25 for the wrong part when you can get the correct part for $10?
- Archiddeon
17 Jun 2011 22:01
I'm not planning on modifying it, and have given up on the $25 '89 one in favour of the $10
If the '89 was the only one I could find, it could probably have been made to work, though
1983 GPz 550
1995 Suzuki GS500E
1995 Suzuki GS500E
