Decal and Paint ??
  • moneypit
  • moneypit's Avatar Topic Author
Decal and Paint ??
16 Jun 2011 00:05
#457538
Im in the process of repainting my body work and need some opinions.
My paint specs call for clear to be sprayed withhin 24 hours of the base coat.
I have to lay the decal in that time, or could I spray a light coat of clear lay the stripes then clear again, I will probably shoot 3 coats clear, yes its 2 part clear. And should I add flex additive to the base and the clear for the plastic parts.
Thanks Bob B)
2-76 kz900
St Paul MN
  • PaintWorkz
  • PaintWorkz's Avatar
Re: Decal and Paint ??
16 Jun 2011 05:31
#457580
Most decal instructions(Reproduction Graphics) call for a paint cure time of at least a week before installing then let decal cure for 2 days before clearing. So clear the color within the 24 hours then wait a week to put on the decals. No flex additive needed.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
  • moneypit
16 Jun 2011 22:08
#457684
Cool. Thank you for the info
2-76 kz900
St Paul MN
  • otakar
  • otakar's Avatar
16 Jun 2011 22:37
#457690
This is why it is better to use Lacquer with these stickers than base-coat clear-coat. If you do not apply the coats within the required amount of time they will peal from each other.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
