Seat cover is tearing!
- mtbspeedfreak
07 Jun 2011 03:46
I noticed that 2 very minor tears have started in my seat cover. Is there anyway to cut my losses? Maybe pull the cover off and tape it (with duct tape from the inside)?
2000 ZRX 1100
1976 KZ 900- Daily Driver
- hocbj23
Re: Seat cover is tearing!
07 Jun 2011 14:03
Take it off,turn it inside out,get some of that heavy duty waxed thread and needle used for lacing leather steering wheels covers and put a couple tight stitches in each tear.Will stop the tearing and doesnt look awful like duct tape.bj
- DoubleDub
07 Jun 2011 15:17
There is also repair kits for vinyl (if you have a vinyl cover) that you can use from the outside once it's sewed up (maybe?) that you can use to fill in the tear and "mold" the edges together again. I used a vinyl repair kit on a rip on the outside edge of my new seat cover that I made and it has held up really well. If the tear is big enough, I would still sew it as recommended to prevent it from ripping further.
Last edit: 15 Feb 2013 10:09 by martin_csr.
07 Jun 2011 16:59
when i installed my new seat cover i managed to tear it a little in one of the seams.i used one of those denim iron on patches your mom used to use to re-enforce the knees in your jeans.cut to size and ironed on the backside then hand sewed it back together.worked so far.
- TeK9iNe
- What did you do!?!
07 Jun 2011 17:33
If you dont mind the flat look (no stitching, etc.), then you can purchase multidirectional stretch vinyl/pleather/etc and just cover right over the seat you have now. It works/looks fantastic if you pull it tight.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Kidkawie
- I bleed premix
07 Jun 2011 17:55 - 07 Jun 2011 17:56
My wife sewed my original Z1B seat cover. Tore on the seam so it wasn't too bad. I got a heavy duty needle set and some upholtery thread. Do it in the sun, more flexible.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 07 Jun 2011 17:56 by Kidkawie.
- mtbspeedfreak
08 Jun 2011 03:51
Thanks for the suggestions guys! Now, if I can only find the time to pull my seat apart.
Bitchen Z1B KidKawie!! That a Hooker pipe?
2000 ZRX 1100
