Sandblasting gas tank
  • ELCouz
  • ELCouz's Avatar Topic Author
24 May 2011 11:24
#453240
Hi,
I know that even an empty gas tank have residual fuel on the metal (and i cannot fill it with water my boss would kill me if water is inside the sandblasting cabinet).
Is it dangerous? Sandblasting create a lot of sparks i don't want to blow the whole cabinet!
Have you done it before ?
regards,
laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
  • pugeyed
  • pugeyed's Avatar
Re: Sandblasting gas tank
24 May 2011 13:24
#453268
would also be interested in this as i have a tank that needs blasting.
have had a tank done before and he just left the fuel cap on .
kz750 h3 1982 4cl
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
24 May 2011 14:33
#453276
Sand distorts sheetmetal. That's why auto restorers use walnut shells or something along those lines.
Personally, I would chemically strip the tank, then I don't have to worry about debris inside of it.
If you're worried about sparks just wash the tank out real good with degreaser, soap and water, dry, tape up the openings and blast.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • MDawnz1
  • MDawnz1's Avatar
02 Jun 2011 03:03
#454921
Sand blasting sheet metal that you want to still be straight is NOT a great idea.
BUT,,,,,,,,
If you must,,,,,,
Plug the petcock hole, put in a little water (maybe 1/4 cup) Throw in a hand full of DRY ice,USE a glove ,when it starts to smoke out of the cap, tape that off too.
Then blast away.
No O2 , No big bang.
1974 Z1a, still 903
  • testarossa
  • testarossa's Avatar
02 Jun 2011 07:51
#454929
tc.v2.cache2.googlevideo.com/videoplayba...1&redirect_counter=2
I'm with Kidkawie. You are already going to have plenty of sheetmetal issues to work out without adding some by sandblasting. Aircraft stripper knocks out old paint faster than you could blast it off. A one quart can of stripper will be plenty for a tank.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Archiddeon
  • Archiddeon's Avatar
08 Jun 2011 02:34
#456067
I've been asking around the sandblasting companies and they all say to use ground walnut shells. Sand is too abrasive (may even wear through the seems) and soda is crazy slow. I've also read that soda can leave behind deposits that make it difficult for the primer to adhere ... but not sure how true that is. Also heard that walnuts leave behind oils that have the same effect ... so who knows!
I've had good success with paint stripper and a wire brush attachment for my drill (the brush eats plastic, so don't try it on the fairing, but does very little to the metal of the tank ... actually gives it a nice finish).
-Arc
1983 GPz 550
1985 Honda CH150 Scooter
1995 Suzuki GS500E
  • dmrcflyr2
  • dmrcflyr2's Avatar
08 Jun 2011 08:37
#456098
I just used paint stripper from WalMart and then a Harbor Freight palm sander to make fast work of getting down to bare metal on the tank.
I considered using the bead blaster at work too; but I used acetone to clean the inside of the tank and it took all gas fumes left too.
Current rides
88 Suzuki VS1400 Intruder
85 Kawasaki ZN700-A2
Former rides
00 Suzuki VS800 Intruder
07 Suzuki DL650 V-Strom
05 Honda Spirit 750
00 Honda Shadow VLX Deluxe
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
08 Jun 2011 12:35
#456134
Archiddeon wrote: I've been asking around the sandblasting companies and they all say to use ground walnut shells. Sand is too abrasive (may even wear through the seems) and soda is crazy slow. I've also read that soda can leave behind deposits that make it difficult for the primer to adhere ... but not sure how true that is. Also heard that walnuts leave behind oils that have the same effect ... so who knows!
Those problems are from not prepping properly before finishing.
1975 Z1 900
2004 KX125
