About to paint cases
  • doped304
  • doped304's Avatar Topic Author
08 May 2011 19:32
#449683
I have sandblasted them and put in my dishwasher. I am using pj1 fast black. My plan was to put 2 or 3 light coats and let it dry. After that i was going to stick them in my powdercoat oven. Should I do a long time at low temp on fairly high temp for a shorter duration?
  • MFolks
  • MFolks's Avatar
Re: About to paint cases
09 May 2011 01:23
#449784
I'd think a long,low temperature cure would make a durable paint job versus a quick, hot one.
  • MFolks
  • MFolks's Avatar
09 May 2011 01:26
#449786
If I'm in a hurry, I'll fire up the oven in the house and after an air dry of an hour, I bake spray painted parts at 350 F for another hour. Open windows as the fumes make the house stink if possible.
  • Jack
  • Jack's Avatar
09 May 2011 13:43
#449848
MFolks wrote: If I'm in a hurry, I'll fire up the oven in the house and after an air dry of an hour, I bake spray painted parts at 350 F for another hour. Open windows as the fumes make the house stink if possible.
If you're married or have a live in girl, you can usually get away with that ONCE. KalGard is the worst, just ask my wife...
Seriously, long and low temp vs, high/ short duration seems to work better
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • MFolks
  • MFolks's Avatar
09 May 2011 16:17
#449871
No, my wife does not object, as long as the house is throughly fume free after I'm done baking parts.
  • doped304
09 May 2011 17:09
#449882
Do I need any adhesion promoter? OR just shoot it on the blasted metal?
  • MFolks
  • MFolks's Avatar
09 May 2011 17:22
#449886
As long as the surface has some "Tooth" (a term used for a good paintable surface) and is oil/grease free, the paint should stick.
