HF soda blaster
- bearshawk
HF soda blaster
03 May 2011 01:36
Anyone use the HF soda blaster or something similar? i want to do some deep cleaning on my project bike this summer and that seems like a decent route to go. any experiences let me know, good or bad
Thanks guys
Thanks guys
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and pods
1998 honda superhawk 1000-fun in the twisties
1982 kz1100 A2 shafty, current project
- wireman
Re: HF soda blaster
03 May 2011 01:43
looks reasonably priced.
i wonder what would be required to convert a cabinet over to soda blasting?
- racer54
Re: HF soda blaster
03 May 2011 16:25
Where is a good place to buy soda media to use in a blaster?
- wireman
Re: HF soda blaster
03 May 2011 16:28
grocery store in little orange boxes! :woohoo:
looks like hf sells it,im sure eastwood sells it also.
i bet you could find it really cheap somewhere
- wireman
Re: HF soda blaster
03 May 2011 16:34
looks like you can get it for about $2.50 ton from the chinese ,but you need to bring your own bag! :blink:
- racer54
Re: HF soda blaster
03 May 2011 16:46 - 03 May 2011 16:48
It doesn't take a special blaster to use soda in does it...different nozzles, etc. I have a blaster but haven't used it yet. I'll check Eastwood. Buy from there on occasion. Out HF didn't have any last time I was there...had other media but not soda but it's a small place...might be able to get some though...have to check again. Wonder if Hy-Vee would freak out if I came to check-out with every box they had onthe shelves? lol
Last edit: 03 May 2011 16:48 by racer54.
- Kidkawie
- I bleed premix
Re: HF soda blaster
03 May 2011 16:51
I use mine all the time, wish I built it when I did my Z1, but I use it all the time on my KX resto. I just buy the $2-3 large boxes of Arm & Hammer, one box can do alot if you play around with pressure. I just throw on a dust mask and some glasses and do my parts outside, then wash them off with the hose. I tried doing a cabinet first but there was no vacuum system so it was just a dust cloud in 5 seconds. The soda is so cheap there's no reason to contain it. Plus with a cabinet you limit the size part you can clean.
Here's my blaster, the hose is shorter now so I can use one hand to hold the part.
Some results:
I initially cleaned my 900 engine by hand, took 2 days and still didn't look great. I sealed off the intake and went around the engine with the soda being very careful not to get the frame or anything painted, then hosed it off.
Some results:
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- kz750saskatoon
Re: HF soda blaster
03 May 2011 17:08
Wow, that does an awesome job!
1981 KZ750-H2
Saskatoon, SK
Saskatoon, SK
- donaldderby
Re: HF soda blaster
11 May 2011 23:38For one way to make it, click > www.aircooledtech.com/tools-on-the-cheap/soda_blaster/donaldderby wrote: howd you make it
- KZCM
Re: HF soda blaster
23 May 2011 20:31
I'm doing a restoration on a 1980 shaft and all the local places wanted big bucks to do any kind of blasting work on it. HF had the 15 pound model on sale for $99.00 and a 50 pound bag of course grade soda is 35 bucks. (They also carry a medium grade.) Best money I ever spent. You do have to give it a good shake now and then to loosen up the contents but otherwise it's a breeze. I'm about halfway through stripping the engine down and still have half a bag of soda left. Way easier than I thought it would be. When I was finished for the day I used the shop vac to recover a good portion of the soda. I might try reusing it just to see what happens.
1977 KZ1000 - Wish I still had it
1980 KZ1000E2 - My project
- riverroad
- 1980 1000LTD B4
Re: HF soda blaster
24 May 2011 11:07
I think I may have just found a source for cheap baking soda. It appears that farmers and ranchers use it in their feed. My local feed store has it in 50 lb bags for twelve bucks.
www.naturalsoda.com/images/feed_Information_sheet.pdf
Don't know how course it is though.
