HF soda blaster
  • bearshawk
  • bearshawk's Avatar Topic Author
HF soda blaster
03 May 2011 01:36
#448474
Anyone use the HF soda blaster or something similar? i want to do some deep cleaning on my project bike this summer and that seems like a decent route to go. any experiences let me know, good or bad
Thanks guys
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and pods :)
1998 honda superhawk 1000-fun in the twisties :)
1982 kz1100 A2 shafty, current project
  • wireman
  • wireman's Avatar
Re: HF soda blaster
03 May 2011 01:43
#448476
looks reasonably priced.
i wonder what would be required to convert a cabinet over to soda blasting?
  • racer54
  • racer54's Avatar
Re: HF soda blaster
03 May 2011 16:25
#448571
Where is a good place to buy soda media to use in a blaster?
  • wireman
  • wireman's Avatar
Re: HF soda blaster
03 May 2011 16:28
#448574
grocery store in little orange boxes! :woohoo:
looks like hf sells it,im sure eastwood sells it also.
i bet you could find it really cheap somewhere B)
  • wireman
  • wireman's Avatar
Re: HF soda blaster
03 May 2011 16:34
#448576
looks like you can get it for about $2.50 ton from the chinese ,but you need to bring your own bag! :blink:
  • racer54
  • racer54's Avatar
Re: HF soda blaster
03 May 2011 16:46 - 03 May 2011 16:48
#448580
It doesn't take a special blaster to use soda in does it...different nozzles, etc. I have a blaster but haven't used it yet. I'll check Eastwood. Buy from there on occasion. Out HF didn't have any last time I was there...had other media but not soda but it's a small place...might be able to get some though...have to check again. Wonder if Hy-Vee would freak out if I came to check-out with every box they had onthe shelves? lol
Last edit: 03 May 2011 16:48 by racer54.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: HF soda blaster
03 May 2011 16:51
#448583
I use mine all the time, wish I built it when I did my Z1, but I use it all the time on my KX resto. I just buy the $2-3 large boxes of Arm & Hammer, one box can do alot if you play around with pressure. I just throw on a dust mask and some glasses and do my parts outside, then wash them off with the hose. I tried doing a cabinet first but there was no vacuum system so it was just a dust cloud in 5 seconds. The soda is so cheap there's no reason to contain it. Plus with a cabinet you limit the size part you can clean.
Here's my blaster, the hose is shorter now so I can use one hand to hold the part.
Some results:
I initially cleaned my 900 engine by hand, took 2 days and still didn't look great. I sealed off the intake and went around the engine with the soda being very careful not to get the frame or anything painted, then hosed it off.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • kz750saskatoon
  • kz750saskatoon's Avatar
Re: HF soda blaster
03 May 2011 17:08
#448587
Wow, that does an awesome job!
1981 KZ750-H2
Saskatoon, SK
  • donaldderby
  • donaldderby's Avatar
Re: HF soda blaster
11 May 2011 22:43
#450396
howd you make it
84 kz700a1
Re: HF soda blaster
11 May 2011 23:38
#450428
donaldderby wrote: howd you make it
For one way to make it, click > www.aircooledtech.com/tools-on-the-cheap/soda_blaster/
Good Fortune! :)
  • KZCM
  • KZCM's Avatar
Re: HF soda blaster
23 May 2011 20:31
#453101
I'm doing a restoration on a 1980 shaft and all the local places wanted big bucks to do any kind of blasting work on it. HF had the 15 pound model on sale for $99.00 and a 50 pound bag of course grade soda is 35 bucks. (They also carry a medium grade.) Best money I ever spent. You do have to give it a good shake now and then to loosen up the contents but otherwise it's a breeze. I'm about halfway through stripping the engine down and still have half a bag of soda left. Way easier than I thought it would be. When I was finished for the day I used the shop vac to recover a good portion of the soda. I might try reusing it just to see what happens.
1977 KZ1000 - Wish I still had it
1980 KZ1000E2 - My project
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
Re: HF soda blaster
24 May 2011 11:07
#453238
I think I may have just found a source for cheap baking soda. It appears that farmers and ranchers use it in their feed. My local feed store has it in 50 lb bags for twelve bucks.
www.naturalsoda.com/images/feed_Information_sheet.pdf
Don't know how course it is though.
