Spray paint Fork Lowers
- Kidkawie
- I bleed premix
Re: Spray paint for Fork Lowers
02 Apr 2011 23:15
Just get them clear annodized.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- grumpy56
02 Apr 2011 23:34
Painted mine black with PJI Pocelain Hard about 2 years ago. Have only put on about 3000 miles, but they have not chipped at all. Just sanded them and sprayed the PJ1 and am happy.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- Beard
03 Apr 2011 00:46
i have heard using oven cleaner for removing that clear coat, if you wanted to make polishing them easier.
79 KZ650B
Jack of everything, Master of nothing.
- DoubleDub
03 Apr 2011 02:17Kidkawie wrote: Just get them clear annodized.
What does that typically run compared to having them painted or powder coated? Sounds like the way to go, I wouldn't have thought of it.
- Kidkawie
- I bleed premix
04 Apr 2011 08:23
I was quoted 100 for a set of mx forks in gold. But ive seen cheaper. You have to shop locally. If the part is already ano, then you need to have that removed chemically first, polish, then reanno. Most polished alu parts come from the factory with clear anno like rims, trees, etc.
1975 Z1 900
2004 KX125
2004 KX125
- larrycavan
04 Apr 2011 09:54
I used the same paint on mine. No issues but they are also modern forks so the lower tubes are much shorter.
- testarossa
04 Apr 2011 10:00racer54 wrote: If I remember right, it was more an adhesive promoter. I remember that you polished your part to the shine you wanted and then sprayed it with this. Just can't remember if it was the final coat or you put on a clear over it.
I'm pretty sure you are talking about adhesion promoter. It is not a top coat. You will need to shoot a clear coat on after the adhesion promoter for protection.
Clear anodize would probably be a good, durable solution. The forks on my bike are factory clear anodized:
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- gengomerpyle
04 Apr 2011 16:10love that color bluetestarossa wrote:racer54 wrote: If I remember right, it was more an adhesive promoter. I remember that you polished your part to the shine you wanted and then sprayed it with this. Just can't remember if it was the final coat or you put on a clear over it.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
