anyone extend a kz400 swing arm?
- khawk912
14 Mar 2011 21:00
whats up guys, id like to extend the swing arm on my kz400 ltd, just want to make sure im doing it right. has anyone done this before? have ideas as to how i should go about it
- khawk912
Re: anyone extend a kz400 swing arm?
14 Mar 2011 21:01
or is there an interchangeable swing arm out there from another bike i should look into?
- treitz
14 Mar 2011 21:01
A guy here in Boise did. Are you on dotheton.com?
He is on there, but not sure that he is on here.
1979 KZ400 - 2-1 Manifold - Mikuni VM34
- wireman
14 Mar 2011 21:24
if you want to extend the stock one id find another one like it,cut one long and other short and slug/sleeve them together
- khawk912
15 Mar 2011 00:56
yea i just picked up an extra one just seeing if anyone maybe had pics of theres i cant find anyones on here to see where they cut it, and if i need to set up a jig or not
- khawk912
15 Mar 2011 01:10
also wanted to know what kind of stock i should pick up? i was told chromoly but then i was told that they didnt use that on the bike so im confused.
- Buckeye73z1
15 Mar 2011 05:11
www.armbell.com/forum/viewtopic.php?t=10...start=0&mforum=kz400
This forum (Kawasaki Twin Owner's Forum) is very helpful with the 400s. The post in the link is about a KZ400 with a 6" stretch. The OP in that thread (Phil) is a really good guy and is very helpful. He fabbed his own stretched swingarm and I'm sure could get you pointed in the right direction. He is in Cincinnati and I live in Dayton and I've seen his work first-hand. Top-notch worksmanship.
1973 Z1 900 cutom-current
1975 KZ 400D cafe racer-sold
1981 Honda CB750c rat bike-sold
2000 ZX12-R-sold when first child born
- Buckeye73z1
15 Mar 2011 05:20
Also, if you only want a minor stretch, the LTD440 swingarm is plug and play and is about 2" over stock. That is what I ran on my old '75 KZ400.
- treitz
15 Mar 2011 07:51
Here's the build thread of the guy here who did it. He extended it 2.5"
www.dotheton.com/forum/index.php?topic=21678.0
- Mercury Kid
03 Apr 2011 18:58
It's a bit of a secret, and takes a bit of creativity, but an EL250 swingarm will add about 6" over your stocker. I've seen it on a KZ440, so it should work for you. It is wider at the pivot point so you either have to narrow it, widen the frame, or bottlejack the frame apart a bit. I don't recommend the jack, but have seen it.
'76 KZ900-Z1 clone
Z1 70's period longbike
