Aluminum paint prep?
  • jjdwoodman
  • jjdwoodman's Avatar Topic Author
  • Live free, or die.
28 Feb 2011 21:12
#434112
Hey all. I've got a project going that involves about 250sf of aluminum treadplate. The owner wants it painted and I'll probabaly be going with a catylised enamel since it will live outdoors.
The plate is new and so it's pretty polished. I was wondering if I needed to wash it down with ammonia or vinegar to etch before priming?
Or do I need to use anything at all?
77 650b
81 550 Mostly there
83 ZN1300 Voyager
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Aluminum paint prep?
01 Mar 2011 02:55 - 01 Mar 2011 02:58
#434126
I believe it follows the same principle as painting chrome, plastics, no primer bare metal etc...
Scuff lightly (green Pad), clean and then use Adhesion Promoter before primer & paint...
Worked on my head light shells, no issues to date.
Here's a write up with images if interested...
kzrider.com/index.php?option=com_docman&...d&gid=455&Itemid=108
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 01 Mar 2011 02:58 by Old Man Rock.
  • Tony
  • Tony's Avatar
    Author
01 Mar 2011 07:52
#434159
This is what we use in the airplane business to prep aluminum for painting.
alumiprep no.33
alodine 1201
  • car2nst
  • car2nst's Avatar
02 Mar 2011 16:26
#434486
anytime you paint aluminum it has to be etched-most auto paint stores sell etching primer by the quart or can actually make it into an aerosol can. most importantly, though, is the etching primer window is faily short, maybe four hours. if you wait too long the primer will seal then you'll have to scuff your surface to open the primer back up.
  • Kawi // Twin
  • Kawi // Twin's Avatar
06 Mar 2011 19:55
#435744
Is this etching and primer neccessary for painting an engine? I am getting ready to paint my KZ650 engine black in the next 2 weeks and am reading all I can about getting it ready.
Thanks!
1978 KZ650 B2
forums.kz650.info/index.php?topic=3569.0
2009 Kawasaki 650R - yes it is a Ninja, but not really
1985 Ninja 900 or GPz900 for everyone else outside the USA
1984 Ninja 900 for restoration
  • car2nst
  • car2nst's Avatar
07 Mar 2011 20:35
#436049
I just painted my kz650 engine using the method I described-etching primer first then top-coated with Imron which is a very durable enamel, basically just short of powder coating as far as durability goes. The short answer is yes, use the etching primer after you have cleaned the engine thoroughly and i mean, thoroughly, then blow completely dry with compressed air and paint-2 or 3 coats of primer, wait and hour and topcoat with whatever you're using and remember,thin coats of paint set up much better than thick ones
  • jjdwoodman
11 Mar 2011 17:37
#437156
Well, there's the good and the bad. The good is the etching wash primer worked great. I used Sherwin Williams kem 400 primer and paint with the catylist. The bad news is I forgot to get pictures of the primer. (It was 3am after a 20 hr. day.)
The bad news is today we loaded the cabinets up on the flat bed to deliver them. I didn't want to strap them down because the paint hadn't fully hardened yet and we already had a few scuffs from loading them. Only 5 miles away to the job site, and it's backroads so I could just drive real slow. I got a mile from the shop and a huge gust of wind came and rocked the truck real hard, and two cabinets eploded all over the pavement.
The good news is now I can get the pictures of the primer after I build new ones.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
