anodizing kits
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
anodizing kits
27 Feb 2011 13:20
anyone used one at home, or in the shop? i was thinking of doing my own parts to cut back in costs. thanks.
- les holt
Re: anodizing kits
27 Feb 2011 13:25
Look up Caswell and
www.e-clec-tech.com
Like you I have been thinking the same thing for a while. There is a few forums for it also. If you do it soon, let us know the results.
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- Stu Pidasole
Re: anodizing kits
27 Feb 2011 13:42
thanks les. it wont be soon.....i would just rather do it myself and save some bucks. ill let yall know.
- lemo32
- The Price of Cool aint cheap
Re: anodizing kits
27 Feb 2011 14:05
Saw a sight the other day, don't have the link, but the guy was talking about making his with a battery charger and some sulfuric acid, didnt sound to expensive.
1979 kz 1000 06 katana 750
- PLUMMEN
- Stu Pidasole
Re: anodizing kits
27 Feb 2011 14:44
lemo32 wrote:
can ya find it lemo?Saw a sight the other day, don't have the link, but the guy was talking about making his with a battery charger and some sulfuric acid, didnt sound to expensive.
- Stu Pidasole
Re: anodizing kits
27 Feb 2011 14:59
heres some pc.....good reviews....
www.harborfreight.com/10-30-psi-powder-c...ng-system-94244.html
- lemo32
Re: anodizing kits
27 Feb 2011 15:28
Its called warpig.com anodizing at home, by jim bowles has alot of good info, wish I could do a direct link up with the site but not that computer savy
Re: anodizing kits
27 Feb 2011 16:30
Depending on application, might also be interested in diy Gun-Kote.
- Jeff.Saunders
Re: anodizing kits
27 Feb 2011 16:34
We've a couple of customers using the Caswell setup. I saw a few parts done using the Caswell kit and they looked good.
- hardr0ck68
- Who put the what in the where?
Re: anodizing kits
27 Feb 2011 18:21
year
www.warpig.com
will have info. All paintball guns are finished with ano, I played with it once upon a time, but it was far cheaper (and you got better results) to just send it out to the flavor of the month ano company.
The common coloring agent back then for the DIY guys was RIT dye, all you really need is the dye, a power source and some chemicals. If you have a failed attempt mix up some common crystalized drain cleaner and water... a dip in that will strip ano off in a few seconds.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
