Tank Emblems
- BIGKEVIN
Tank Emblems
24 Jan 2011 15:55
I just got a 1976 KZ900. The tank has been painted and the emblem holes filled. I just got some badges from AmericanCassix and the badges are straight and need a curve to them in order to fit the tank. Is there a way to clean the attachment holes out to fit the screws in or is applying glue/tape my only choice ? Also, how can I get the badges to get the curve into them without breaking them ?
1976 KZ900
2006 ZX6R
2006 ZX6R
- testarossa
Re: Tank Emblems
24 Jan 2011 15:59
If you know exactly where the holes are located, you can drill out the filler with a 2.5mm drill bit. Then chase the threads with a M3 x 0.5mm tap. The badges should bend easily by hand to the curve of the tank.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- PLUMMEN
Re: Tank Emblems
24 Jan 2011 16:00
holes are probably full of bondo,hard to remove without messing up paint.
bend them a little at a time slowly along length of emblem,keep checking progress
- lemo32
- The Price of Cool aint cheap
Re: Tank Emblems
24 Jan 2011 18:22
You might be able to run a magnet across each side of tank, get you close, 3m makes a good emblem adhesive, just sucks if you ever need to remove emblems.
1979 kz 1000 06 katana 750
- Kawboy74
Re: Tank Emblems
24 Jan 2011 19:50
Try putting some felt or kraft paper behind the badges when bending them to protect the paint. The badges are soft aluminum and will bend easy so you can bend gently by hand and check occasionally for fit. The mounting screws if properly located will also help to conform them to the tank side profile.
Good luck! david
Good luck! david
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
- PaintWorkz
Re: Tank Emblems
25 Jan 2011 01:18
You can clean the bondo out of the screw holes if you can find them and hopefully the plates have not been cut off, hammered down, brazed up, or badly dented in before the bondo was applied. :ohmy:
Also some of the reproduction emblems are a hard diecast and are tough to bend. Seems like only the ones that come from Kawasaki or their supplier are soft aluminum and form easily to the tank shape.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
84 Gpz900 street
77 1135 KZ900 A5
- Old Man Rock
Re: Tank Emblems
25 Jan 2011 02:04
ACE Hardware: E6000
Use this at work on plastics and glass... Dries & bonds rubbery and holds up well in heat or cold... COmes in clear or black.
Beauty is if you need to pull off it peels all in one piece compared to RTV...
$6... Good stuff....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- JMKZHI
Re: Tank Emblems
25 Jan 2011 06:25
If you decide to drill out the holes, do not drill thru the tank.
Several folks here on KZR have done that.
