Rust in tank
- KZQ
- Administrator
Re: Rust in tank
08 Jan 2011 17:33
Copious amounts of water are a good thing. Fortunately, acid does not attack paint like a solvent might.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- RonKZ650
Re: Rust in tank
08 Jan 2011 18:07
Acid doesn't faze the stock paint, but this is a repaint. Just getting rained on once ruins the majority of them, so I'd be extra careful. all the sealers, POR15, Bill Hirsch, Kreme, ect work ok, but need a clean tank to adhere to. One thing I've mentioned in the past, but just to reinterate, if you use sealer, get the tank clean with heavy acid. Don't skimp or "be safe", by going 10% on the acid/water ratio or your job will fail. Other than this, the biggest cause of failure is coating too thick. Put in the sealer, coat the tank, drain it when it's still thin, then maybe repeat once. No need or benefit to coating to a 1/8 thick glob of plastic coating.
- trianglelaguna
Re: Rust in tank
08 Jan 2011 18:12
okay
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- SteveMS
Re: Rust in tank
16 Mar 2011 17:45
Try this:
www.altelco.net/~jacil/clay/motorcycle/KElecSetup.html
I have not tried this, but it sure as hell looks as if it will.
- beefsquasher
Re: Rust in tank
16 Mar 2011 18:00
I have used a product called OSPHO by a company called Skyco. It dissolves rust, but is pretty gentle and does not seem to harm paint like muriatic acid will. It's mainly phosphoric acid, with a few additives to make it coat and penetrate rust better. Sells by the gallon, and a gallon will last a long long time.
I use about 2-3 cups in a tank, then fill it the rest of the way with hot water. Let it sit for about a day. Drain it out, and rinse thoroughly. Drain as much water as you can, then stick a hairdryer in it set as low as it will go, or even on cool.
Works great. If you are worried about pinholes, they generally happen on the seams. I use kreem and just use enough to fill in the seams at the bottom of the tank. It's not really necessary to coat the whole inner surface of the tank as long as you keep gas in the tank and dont let it sit out in the rain for years. I have done this on three of my bikes and they all came out great and are both leak-free and rust free to this day.
-Dave
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- KZQ
- Administrator
Re: Rust in tank
16 Mar 2011 19:16
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- testarossa
Re: Rust in tank
16 Mar 2011 22:17
I have removed rust using "The Works" toilet cleaner, but the tank needs to be filled or coated quickly. Flash rust happens fast. I would recommend POR 15 if your tank needs a liner. Stay away from Kreem IMO. I have one bike with a Kreem liner applied by the PO and it's not fairing well. Not well adhered to the tank and occasionally it liberates a bit of the lining which immediately cloggs the fuel filter.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- stonemaster
Re: Rust in tank
16 Mar 2011 22:35 - 16 Mar 2011 22:36
testarossa wrote:
+1 ON kREEM, one word OXALIC ACIDI have removed rust using "The Works" toilet cleaner, but the tank needs to be filled or coated quickly. Flash rust happens fast. I would recommend POR 15 if your tank needs a liner. Stay away from Kreem IMO. I have one bike with a Kreem liner applied by the PO and it's not fairing well. Not well adhered to the tank and occasionally it liberates a bit of the lining which immediately cloggs the fuel filter.
Last edit: 16 Mar 2011 22:36 by stonemaster.
- testarossa
Re: Rust in tank
16 Mar 2011 22:42
stonemaster wrote:
testarossa wrote:+1 ON kREEM, one word OXALIC ACIDI have removed rust using "The Works" toilet cleaner, but the tank needs to be filled or coated quickly. Flash rust happens fast. I would recommend POR 15 if your tank needs a liner. Stay away from Kreem IMO. I have one bike with a Kreem liner applied by the PO and it's not fairing well. Not well adhered to the tank and occasionally it liberates a bit of the lining which immediately cloggs the fuel filter.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- testarossa
Re: Rust in tank
16 Mar 2011 22:43
stonemaster wrote:
That's two words.
That's two words.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- stonemaster
Re: Rust in tank
16 Mar 2011 22:48
yea i noticed that after i posted WTH
stuff works great, I've done 2 tanks with it
Kreem sux, I saw it come off in sheets
- ravenz07
Re: Rust in tank
16 Mar 2011 23:25
After having to deal with the Kreem someone put in my tank, I will never use it. I am sold!
1994 Kawasaki KZ1000 Police
1980 Kawasaki KZ750 LTD
1981 Yamaha XJ650H Maxim
