Securing your sidecovers
  • mtbspeedfreak
  • mtbspeedfreak's Avatar Topic Author
31 Dec 2010 00:12
#419454
Gents,
What's the best way to secure your sidecovers? One blew off awhile back, I just got a new one painted and detailed to match. I have replaced all 6 rubber grommets (made a noticeable difference right off the bat).
I'd prefer not to do the whole drill press/zip tie routine.
Thanks,
Mark
2000 ZRX 1100
1976 KZ 900- Daily Driver
Re: Securing your sidecovers
31 Dec 2010 06:38 - 31 Dec 2010 07:02
#419467
Here's one option.
Last edit: 31 Dec 2010 07:02 by Patton.
31 Dec 2010 06:47 - 31 Dec 2010 07:01
#419468
Another option is to use a spring clip where one nipple is reasonably accessible with side cover in normal position.
The pic below illustrates clip position through nipple.
Clip is inserted last, with side cover in normal position after nipple is fitted through the grommet, to prevent nipple from leaving the grommet.
Must of course remember to remove the clip before attempting to remove the side cover.
Last edit: 31 Dec 2010 07:01 by Patton.
  • z1kzonly
  • z1kzonly's Avatar
31 Dec 2010 07:01
#419470
Seeing you have new grommets, good.
I used to wrap some electrical tape around the side cover nipple, gave it a little extra diameter.
It pushed in nice and tight.
31 Dec 2010 07:07 - 31 Dec 2010 07:08
#419471
Reportedly, using pods instead of the stock air-box allows more wind pressure under the side covers making them more prone to blow off and away from the bike --- at least on some bike models.
Good Fortune! :)
Last edit: 31 Dec 2010 07:08 by Patton.
  • gnfreak
  • gnfreak's Avatar
31 Dec 2010 08:35
#419476
Patton wrote:
Here's one option.
i used this option. i just went to the fishing tackle box and got two 9" steel leaders and connected the covers to the bike frame.
Normal, IL
1980 KZ1000-G1 Classic - Sold
  • trianglelaguna
  • trianglelaguna's Avatar
31 Dec 2010 09:54
#419482
i used smaller drill bit and some fine wire that i had
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • AlienTech
  • AlienTech's Avatar
31 Dec 2010 11:21
#419506
I used some of that epoxy putty to build up the studs on the covers and left the trailing edge "sharper" than stock so it has great grip... when I lost mine it was on the 427N and I had an idea where it flew off, went home tossed the wife on the back so she could jump off and grab it quickly before we could get run over :)
1976 KZ900
  • KZ1979LTD
  • KZ1979LTD's Avatar
31 Dec 2010 11:31
#419508
Wow! That's two things wives are good for!
  • stonemaster
  • stonemaster's Avatar
31 Dec 2010 12:28
#419510
I wonder how a circlip or snap ring would work ? yea I had one blow coming up I 40 A semi squashed it
  • racer54
  • racer54's Avatar
31 Dec 2010 13:17
#419514
I have seen where a guy used a spring attched to both covers to "tie" them together. Takes away someof the underseat space but it worked good. Just attach the spring to a tab on each side cover and stretch between each side, Keeps tension pulling them in to each other. Just another idea to throw out there. I personally use those spring clips on mine but they can be a pain sometimes. Although it's better then losing a cover...
  • trianglelaguna
31 Dec 2010 13:58
#419517
i used the fine jewelers type wire that i had salvaged somewhere ...and a tiny hole the just wrap it around whatever
1976 KZ900
2003 ZX12R
2007 FZ1000
