Removing Decals
- Riecken
Removing Decals
23 Apr 2006 12:44
Just bought an 80 KZ1000 LTD and decals are worn. Can anyone tell me how to remove the original tank, side cover, and tail fin decals without damaging the paint? Bought some new decals also, what is the best way to apply them and get it right?
- rstnick
Re: Removing Decals
23 Apr 2006 14:12
Welcome.
As far as removing decals, heating them with a blow dryer, as you carefully peal at the edge, usually makes them come off very easy.
I got some decals recently that came with these instructions:
First make sure the area is clean.
Add 3 drops of dish detergent to one quart of water.
Spray a liberal amount of the water solutuion on the surface of the Tank/etc.
Peel the backing off the decal, and apply the same water solution to the backside of the decal.
Apply the decal to the Tank/etc. and move into desired position (I had to be good on placement as mine did not want to move).
Using a firm but soft squeege (Not metal, as this would cratch decal. I used a Library card which was more flexable than a credit card), work the excess water out from under the decal starting from the center and working to the edge.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- MattBlack
Re: Removing Decals
23 Apr 2006 20:42
Haordryer should work fine. I used a heat gun for the badges on my car. Just have ot be careful abuot how much heat you throw on there. Also, with my cars badges a piece of fishing line helped take them of clean. Just heated it up, got an edge up, slid the fishing line in behind and pulled it through the hot glue. Then use a little Goo-Gone to wipe away the extra residue. WD-40 seems to work quite well too. Just wash it all off with soap and water after.
- JMKZHI
Last edit: 03 Dec 2008 17:42 by JMKZHI.
- kx_125_pilot
Re: Removing Decals
24 Apr 2006 11:50
3M makes a rubber wheel that goes on a dril, that grips the decal and takes it off.....then use a solvent to wipe the glue off
- wireman
Re: Removing Decals
24 Apr 2006 12:00
i was trying to remember who made those wheels last week when someone was asking about removing stickers,thanks!
- patmann
Re: Removing Decals
24 Apr 2006 13:47
I don't think these will come off that easy... At least not without damage to the paint. As some of these are clear coated.
Contact member MARK WING on here. This is what the man does for a living ( paint and body ).
Good luck!
Pat
Good luck!
Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
- Riecken
Re: Removing Decals
24 Apr 2006 13:57
Thanks for all of your input. I will try to contact Mark as I was wondering about them being clearcoated.
RRR
RRR
- kx_125_pilot
Re: Removing Decals
24 Apr 2006 18:13
wireman wrote:
ok, i was wrong.....i went out to my dads shop to check, and his is made by ultra-pro which i believe is a napa UAP product. 3M might make one however, but i know for sure ultra-pro does
- Snakebyte
Re: Removing Decals
11 May 2006 04:25
I found some at a auto parts store for $10 in the paint section.
