Glass bead blasting
- andy9802gt
- If it tastes that good, eat it yourself.
Glass bead blasting
21 Dec 2010 13:25
My motor is at the blasters getting cleaned and he tried a plastic bead on it and it didn't give the finish I was looking for. So he said he would blast it with #12 glass bead and I was wondering if anybody had any input on this, if it's going to leave a luster being that fine grit.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- kz1k
- You Cant Fix Stupid!
Re: Glass bead blasting
21 Dec 2010 13:27 - 21 Dec 2010 13:29
never used it. baking soda works nicely.
1978 KZ1000A2
Last edit: 21 Dec 2010 13:29 by kz1k.
- Brown Bear
- porchev914
21 Dec 2010 23:17
I don't know what gradation of glass bead was used, but a shop bead blasted my cylinder, and it looked better, but not great. I took it to a polishing deburing shop and they blasted my engine parts with stuff..... they wouldn't tell me what exactly they used, but my engine cases,cylinder and head looked better than new. That really doesn't help you much, does it? :S
FRANKEN Z!
- XL777
26 Dec 2010 23:02
I had my whole block glass blasted and it leaves a soft satin type finish. I like it but if you want a glossy finish then you will have to polish. Gets the years of grim and oxidation off great!
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- kzr750r1
27 Dec 2010 08:24 - 27 Dec 2010 08:35
Sounds like it's cleaned off on the first pass it shouldn't take much with the glass to get an even finish. However if your looking for a polished finish you could try another pass with the baking soda and see if it evens it out and cuts less off the surface.
For bead blasting of any kind it's not only the tool but how it's used.
Making passes that overlap each other with any material will help produce an even surface to start with.
Good Luck.
Good Luck.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
Last edit: 27 Dec 2010 08:35 by kzr750r1.
