Nason Ful-Thane ?
- texasfisherdude
- 2 old 2 fat dont care
Nason Ful-Thane ?
18 Dec 2010 17:30
I'm about to paint my frame and I have a gallon of black Nason Ful Thane. The problem is I cant find any reducer not even on flea bay. Is there any thing I can use as a substitute? I have the catalyst.
Life's to short to drink cheap beer
1980 LTD 1000
1980 LTD 1000
- seanbarney41
- '79 kz1000 LTD '75 Honda CB750
Re: Nason Ful-Thane ?
18 Dec 2010 17:35
I would try any generic urethane reducer. Go ask the guys at a automotive paint suppliers. If none available or they don't know, try mixing up a small amount with any urethane reducer and test it.
- texasfisherdude
18 Dec 2010 17:53
Thats what I was thinking. I had some urethane reducer in the garage but I cant find it. I did find a Qt of reducer with no label so mabey I'll mix up a little and see if turns to goo
1980 LTD 1000
1980 LTD 1000
- PaintWorkz
19 Dec 2010 01:55
Talk to your local Dupont Autobody supply store, the recommended 441-2x reducer should be available or there should be a correct substitute. If you use a generic enamel reducer it might spray alright, but you could have issues down the road. The reducer is cheap compared to the color and catalyst you already have on hand. Nason has a tech line you can call if the local store does not help you.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
84 Gpz900 street
77 1135 KZ900 A5
- texasfisherdude
19 Dec 2010 14:08
Well the paint turned out to be NG I dont know how but it turned grey when I mixed it up so I used something else.
1980 LTD 1000
1980 LTD 1000
