engine coatings
- kz1k
- You Cant Fix Stupid!
engine coatings
10 Dec 2010 11:47
i was sure there was a thread on what rattle can ti temp paint could be used on our engines. where is it? and if not, here we are....whats the best? silver, black?
1978 KZ1000A2
- stonemaster
Re: engine coatings
10 Dec 2010 12:04
color is up to u , i use VHT but there are others, surface prep is key for any of them
- kz1k
Re: engine coatings
10 Dec 2010 12:12
what is the hottest a 1000 motor would get?
1978 KZ1000A2
- T_Dub
Re: engine coatings
10 Dec 2010 12:13
I used Duplicolor engine enamel, no primer, but I sandblasted and used a prep chemical similar to por15's metal ready. Supposed to promote adhesion on metal surfaces.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- kz1k
Re: engine coatings
10 Dec 2010 12:27
i got off the phone with vht. they said that 650f engine coat would be fine. also they said i could use the clear over the paint. not sure how well it would breathe.
1978 KZ1000A2
- subby
Re: engine coatings
10 Dec 2010 15:55
I use to paint all my motors with heat resistant paint (vht engine enamel) until I was cheap and couldn’t afford it this one time…
I used an industrial single Pac enamel that I had in the garage just to see if it would be successful, so far this enamel has been sprayed on 3 motors and the paint has not blistered, faded, cracked, pealed what ever on any of them, first one was done over 3 years ago….
I have used some cheap enamel rattle cans in the past with no success, found they fade/cloud when heated. What I do know is industrial paint has better properties in certain areas (hence being industrial) heat and adhesive properties are 2 areas, with that in mind I would have no hesitation using industrial enamel and I do, on any motor I have.
in the stable:
1981 Kawasaki KZ750
1980 Suzuki GS1000
1980 Suzuki GSX750
1982 Yamaha XJ650 TURBO (3 of)
1981 Kawasaki KZ750
1980 Suzuki GS1000
1980 Suzuki GSX750
- TerryK
Re: engine coatings
10 Dec 2010 16:05 - 10 Dec 2010 16:07
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 10 Dec 2010 16:07 by TerryK.
- trianglelaguna
Re: engine coatings
10 Dec 2010 16:27
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- trianglelaguna
Re: engine coatings
10 Dec 2010 16:30
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- timebomb33
Re: engine coatings
10 Dec 2010 17:19
i use pj1 or vht on all of my engines that get painted the key is good prep work and cleaning the components properly so you don't have any spots the paint wont adhere to.
I THINK MY POWERBAND BROKE
- steell
Re: engine coatings
11 Dec 2010 10:02 - 11 Dec 2010 10:03
Used a Fluke infrared temp gun to measure temps on a 650 a couple years ago. Hottest temps we observed were around 400-450f near the exhaust ports, rest of the motor was cooler of course.
Last edit: 11 Dec 2010 10:03 by steell.
