GPZ750 clean up
  • Headly
  • Headly's Avatar Topic Author
GPZ750 clean up
25 Nov 2010 02:08 - 25 Nov 2010 02:11
#414144
Gday guys,just thought id share some pics of a GPZ750 i got cheap and are slowly tidying up in between other projects,kids,missus etc.Welded some of the plastics that were damaged by using a soldering iron to melt and "shovel" hot plastic into breaks,then grind back and fill with 2 pack filler/primer,the rear guard was in to pieces was surprised how well it worked for a first go at it.Painted in black base coat,got a mate to make the decals for a slab of beer using pics i found on the net with sticker kit pics and using old stickers under the paint to get the right dimensions.Just got to finish the upper and lower fairing then i will clear coat the lot together.Pics are a bit shitty coz theyre taken with my phone but you get the idea.:) Thanks for lookin,by the way does anyone know if the 900 or 1100 rear guard and tail light from the same era will fit my 750 coz mine is missing(A3 1985 i believe).cheers....:huh:
73z1a fireblade front&rear,75z1b,74z1a,05 husky 510,xl567.
Ask the toe cutter,he knows who i am!
Last edit: 25 Nov 2010 02:11 by Headly. Reason: file to big
  • Headly
Re: GPZ750 clean up
25 Nov 2010 02:25
#414145
Another so far:)
  • Headly
Re: GPZ750 clean up
25 Nov 2010 02:27
#414146
Again:laugh:
  • Headly
Re: GPZ750 clean up
25 Nov 2010 02:32
#414147
  • Headly
Re: GPZ750 clean up
25 Nov 2010 02:35
#414148
B) The lad
  • camaroguy
  • camaroguy's Avatar
Re: GPZ750 clean up
25 Nov 2010 02:46
#414149
Looks good. those stickers look right proportionally.your are going to clear over everything then?I need to find someone to do my 2 stripes for my tank.
  • Headly
Re: GPZ750 clean up
25 Nov 2010 03:09
#414151
Yeah i will clear the lot all at once when the fairings are done,i have a picture of the sticker kit if you like i can send it to you in an email and measure the size of the tank stickers unless you can copy your original ones?
Re: GPZ750 clean up
25 Nov 2010 04:40
#414153
Huge improvement! Keep up the good work.
  • Headly
Re: GPZ750 clean up
28 Nov 2010 03:02
#414511
Threw some clear coat on it today....
  • Headly
Re: GPZ750 clean up
28 Nov 2010 03:03
#414512
  • trianglelaguna
  • trianglelaguna's Avatar
Re: GPZ750 clean up
28 Nov 2010 11:33
#414551
much nicer
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • gpzman2000
  • gpzman2000's Avatar
Re: GPZ750 clean up
28 Nov 2010 18:01
#414609
Holy COW ! How in the world did you get the graphics and paint to look factory original ? I have the exact same bike, and I've been scouring the four corners of the earth to even find a 'clue' as to how to do this !
