How can I prevent paint chipping around gas cap?
  • JMKZHI
  • JMKZHI's Avatar
Re: How can I prevent paint chipping around gas cap?
15 Nov 2010 09:24
#412870
Yes, I'd be very careful using a funnel. The homemade milk jug jobbie worked fine the few times I did it that way, since the jug's opening was large enough to fit the nozzle thru & I could see the fuel level in the tank. But it was a nuisance, so I quit doing it that way. I also fill up to about the level indicated in the owner's manual & w the bike on the center stand.
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
16 Nov 2010 15:04
#413043
You know I have had two tanks painted on my bikes. I am anal about details. Paint still comes off around the edges. There is something that autobody shops miss in putting in the paint I think because my friend got his painted by a professional and his didn't do that at all.
Gotta be some kind of hardener or maybe the tanks are baked or something but it's a PITA to spend that kind of money getting bike painted and find later the paint doesn't work like it should. The fumes come off the tank. So on a hot day you don't necessarily have to spill any gas on the side ever. None of my factory paint bikes have I had that problem with. Just the tanks I had painted.
79 LTD B3
  • Becker
  • Becker's Avatar
  • The Doctor Will Rise Again
17 Nov 2010 08:15
#413152
I was thinking along the same lines as you sax. My 750 has the factory paint job and all it has is a little wrinkling around the filler neck. After 30 years and surviving my learning experience with motorcycles it should be way worse. Maybe the clear coat from the factory is different. Maybe one of the painters that know more about these things will chime in.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • PaintWorkz
  • PaintWorkz's Avatar
17 Nov 2010 08:37 - 17 Nov 2010 08:38
#413156
Quit spilling gas on the tank or filling it too close to the to. Gas gets hot expands and comes out the vent. Make sure the rubber cap gasket is good and keep a good coat of wax on it in case of spills. Rewax after any spills.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
Last edit: 17 Nov 2010 08:38 by PaintWorkz.
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
18 Nov 2010 12:35
#413307
Well, I can say this, I have overtopped my original paint tank and had to wash off the gas a few times before yet I never experienced any problems, ever. None of my other bikes have I had these issues with either.
Gas is very corrosive to paint for sure but a week after I get my tank painted and it bubbles up is not acceptable as I never spilled on it or overfilled it. IMHO
The fumes on a hot day are enough for that reaction to happen. I always sit my bike on its side when I fill the tank and at least two inches from the top so I don't believe on my part that I am doing anything wrong. I just think the paint or additives are not quality enough. Also the painters like to paint the lip. I think therein lays the problem. On my stock tank the paint on the neck is like over spray, a very thin coat. On my painted tanks that bubbled both were painted.
Question is would that be easily fixed or does it have to be completely repainted.
79 LTD B3
  • seanbarney41
  • seanbarney41's Avatar
  • '79 kz1000 LTD '75 Honda CB750
18 Nov 2010 13:45
#413317
I'm pretty sure any early to mid 70's factory candy paint is nitrocellulose lacquer which all modern basecoat/clearcoat paint is supposed to be so much more durable!? Someone on here must know something about the factory painting process.
  • Topper
  • Topper's Avatar Topic Author
18 Nov 2010 15:43
#413335
Well it sounds like the answer to my original question is there isn't much I can do to keep the paint from chipping and peeling around the filler hole. Sounds like it's a fairly common problem with non factory paint jobs.
Best suggestion I've heard so far is to remove the paint from the neck and hole and put a good coat of wax on the tank.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • PaintWorkz
19 Nov 2010 02:34
#413386
Paint from the mid to late 70's was mostly acrylic lacquer and that is what the Kawasaki Candytone paint acts like. The new urethane paints are more durable when done right, but if recommended dry times between coats are not followed, or products are mis-matched, or tank was not cleaned or prepped correctly, I can see the clear wrinkling when soaked with gas due to a poor chemical bond between base coat and clear, or original paint and primer. Also paint manufacturers say to let paint cure for 3 months before waxing, so if you gas up a one week old paint job you are asking for trouble. It takes a paint job a year to cure before it gets good and hard.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
  • seanbarney41
19 Nov 2010 13:15
#413441
Paintworkz, thanks for some straight answers. That clears up a lot of confusion.
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
29 Nov 2010 16:22 - 29 Nov 2010 16:25
#414691
Nice! Thanks for the feedback. I'm sure I need to have you guys give me a quote for my 80 project I am doing. PM me with your ideas for a nice bling paint job. You have my vote. I like black black and deep black.
This guy that painted my bike never even mentioned to me about that happening. I guess when you paint cars for a living those aren't issues that come up.
79 LTD B3
Last edit: 29 Nov 2010 16:25 by saxjonz.
