raw metal finishes
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
raw metal finishes
04 Nov 2010 05:42
#410698
hi guys. i have a project where i will be painting the inside but using a flapper wheel grinder on the outside to get the raw metal look. how can i keep it from rusting? clear spray can laquer? or will that rust?
1978 KZ1000A2
  • DoubleDub
  • DoubleDub's Avatar
Re: raw metal finishes
04 Nov 2010 05:51
#410700
Will this be a motor or something that gets a lot of heat?
  • chance
  • chance's Avatar
  • Life long biker/
04 Nov 2010 05:52
#410701
Should work. Auto clear would work best. Make sure its clean and put several coats..
  • kz1k
04 Nov 2010 05:56 - 04 Nov 2010 06:02
#410704
no, just outdoors....max heat 100 degrees, or inside too. rain would be the worst weather and sun beating down on it. its acually a sculpture. and its steel horseshoes.
1978 KZ1000A2
Last edit: 04 Nov 2010 06:02 by kz1k.
  • H1Vindicator
  • H1Vindicator's Avatar
04 Nov 2010 06:56 - 22 Jan 2013 01:30
#410720
Last edit: 22 Jan 2013 01:30 by H1Vindicator.
  • porchev914
  • porchev914's Avatar
04 Nov 2010 07:31
#410726
Automotive clear would be the most durable, but also the most expensive option. You could try a marine grade varnish or something like that to see how well it works, and switch to auto clear if it doesn work out.
FRANKEN Z!
  • Mark Wing
  • Mark Wing's Avatar
04 Nov 2010 08:12
#410729
we powder coat the part with clear.
Mark
Yorba Linda Cal.
  • kz1k
04 Nov 2010 10:10
#410735
Mark
i was thinking powder coat....my dad has the tools to powder coat small race car parts oven size......but most of my pieces will be larger than that.......hmmmmmm. they dont make anything yet huh....in puff can? that would be the easiest applicaion. is there a high temp clear puff can that may work better than a rustoleum acylic?
1978 KZ1000A2
  • kz1k
04 Nov 2010 10:15
#410737
1978 KZ1000A2
  • kz1k
04 Nov 2010 10:17
#410738
1978 KZ1000A2
  • z1kzonly
  • z1kzonly's Avatar
04 Nov 2010 10:39
#410744
kz1k wrote:
Mark
Stay on track! 100 degree horesshoes. Or high temp parts? Too big for powdercoating in an oven.
  • kz1k
04 Nov 2010 10:42
#410747
z1kzonly wrote:
kz1k wrote:
Mark
you stay on track.......horseshoes will be welded together making them too large for a conventional oven. 100 degrees outside...max temp, but would hi temp be more durabe?
anyway i found the stuff ill use here...
1978 KZ1000A2
