raw metal finishes
- kz1k
- You Cant Fix Stupid!
raw metal finishes
04 Nov 2010 05:42
hi guys. i have a project where i will be painting the inside but using a flapper wheel grinder on the outside to get the raw metal look. how can i keep it from rusting? clear spray can laquer? or will that rust?
1978 KZ1000A2
- DoubleDub
Re: raw metal finishes
04 Nov 2010 05:51
Will this be a motor or something that gets a lot of heat?
- chance
- Life long biker/
04 Nov 2010 05:52
Should work. Auto clear would work best. Make sure its clean and put several coats..
- kz1k
04 Nov 2010 05:56 - 04 Nov 2010 06:02
DoubleDub wrote:
no, just outdoors....max heat 100 degrees, or inside too. rain would be the worst weather and sun beating down on it. its acually a sculpture. and its steel horseshoes.Will this be a motor or something that gets a lot of heat?
1978 KZ1000A2
Last edit: 04 Nov 2010 06:02 by kz1k.
- H1Vindicator
Last edit: 22 Jan 2013 01:30 by H1Vindicator.
- porchev914
04 Nov 2010 07:31
Automotive clear would be the most durable, but also the most expensive option. You could try a marine grade varnish or something like that to see how well it works, and switch to auto clear if it doesn work out.
FRANKEN Z!
- Mark Wing
04 Nov 2010 08:12
we powder coat the part with clear.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- kz1k
04 Nov 2010 10:10
Mark Wing wrote:
i was thinking powder coat....my dad has the tools to powder coat small race car parts oven size......but most of my pieces will be larger than that.......hmmmmmm. they dont make anything yet huh....in puff can? that would be the easiest applicaion. is there a high temp clear puff can that may work better than a rustoleum acylic?we powder coat the part with clear.
Mark
1978 KZ1000A2
- kz1k
04 Nov 2010 10:15
1978 KZ1000A2
- kz1k
04 Nov 2010 10:17
1978 KZ1000A2
- z1kzonly
04 Nov 2010 10:39
kz1k wrote:
Stay on track! 100 degree horesshoes. Or high temp parts? Too big for powdercoating in an oven.
Mark Wing wrote:i was thinking powder coat....my dad has the tools to powder coat small race car parts oven size......but most of my pieces will be larger than that.......hmmmmmm. they dont make anything yet huh....in puff can? that would be the easiest applicaion. is there a high temp clear puff can that may work better than a rustoleum acylic?we powder coat the part with clear.
Mark
- kz1k
04 Nov 2010 10:42
z1kzonly wrote:
anyway i found the stuff ill use here...
you stay on track.......horseshoes will be welded together making them too large for a conventional oven. 100 degrees outside...max temp, but would hi temp be more durabe?kz1k wrote:Mark Wing wrote:i was thinking powder coat....my dad has the tools to powder coat small race car parts oven size......but most of my pieces will be larger than that.......hmmmmmm. they dont make anything yet huh....in puff can? that would be the easiest applicaion. is there a high temp clear puff can that may work better than a rustoleum acylic?we powder coat the part with clear.
Mark
1978 KZ1000A2
