need super lite gas tank for drag bike
- bwill166
19 Oct 2010 14:26
I have a 75 kz 900 drag bike. I'd like to find a plastic or fiberglass tank for it to lose some weight. Any sugestions?
- kaw a bong a
- Have a 1978 kz 650 b and a 1976 kz 900z1ltd
Re: need super lite gas tank for drag bike
19 Oct 2010 15:14
I saw a you tube video where a guy has a kz drag bike on a dyno,he stops for a second and pulls the entire tank and seat and tail off in one piece ,so I assumed there was a small fuelcell.just a thought.
1978kz650b 1976kz900 first bike 1979kz 400
- kaw a bong a
19 Oct 2010 15:16
- Jack
19 Oct 2010 16:44
Here you go :
www.beasleycomposites.com
. Great stuff ,very satisfied customer since the 80's.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- racer54
31 Oct 2010 12:33
Beaseley makes a tank shell. Older tanks of fiberglass were either 1 qt., gallon or full capacity and monted using stock tank mug mounts. Very hard to find nowadays though. Under the tank shell most racers use a backbone fuel cell. You can make one or D&G Chassis sells them. I think they are about $135. I have a tank shell made out of a stock tank. Just cut the bottom of tank out leaving just the outer shell and the mounts intact. Be sure to cut in a way so that the mounts aren't structurally weak. This way you have a strong tank shell that doesn't flex like a fiberglass shell might (although it depends on how yo mount the glass shell) and it is a lot lighter then a full stocker.
