Gas tank compatability?
  • Mjsenz
  • Mjsenz's Avatar Topic Author
17 Oct 2010 13:48
#407242
I just bought a mechanically immaculate 1976 KZ400 for my wife, and the only thing wrong with it is a faded and dented gas tank. I see they're fairly common on eBay, and was wondering what other years or models would be interchangeable with the fittings on ours. Any and all feedback is very much appreciated.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Gas tank compatability?
17 Oct 2010 15:32
#407252
You do not indicate which model you have. But I found the following on the Kawasaki web site. That the d3 from 76 and the d4 from 77 used the same tank and that the s2 from 76 and the s3 from 77 shared the same tank.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Mjsenz
17 Oct 2010 17:18
#407270
How do I determine the model?
  • gd4now
  • gd4now's Avatar
17 Oct 2010 23:36
#407354
First I am not familar with the kz400 models but most likely you can determine which model you have via the vin or frame number. I think there were 2 models offered in 76 a standard and a special.
You will find info on both models on this site under the KZ Information menu or use this link kzrider.com/index.php?option=com_content...d=6&id=235&Itemid=50
Use the info there to compare the frame or engine number on your bike to determine what you have.
1977 KZ650 B1
  • loudhvx
  • loudhvx's Avatar
18 Oct 2010 00:31 - 18 Oct 2010 00:32
#407360
The D model has a front disk brake, dual exhaust, and electric start.
The S model has front drum brake, 2-into-1 exhaust, and no electric start (and smaller battery). It also has no tachometer.
The carb jetting is slightly different too.
Last edit: 18 Oct 2010 00:32 by loudhvx.
