Stripped Kawasaki emblem screws
  • Kapahulu
  • Kapahulu's Avatar Topic Author
27 Sep 2010 19:23 - 27 Sep 2010 19:23
#402338
I'm trying to remove the Kawasaki emblems from a tank and the screw heads are stripping! Thinking about drilling them and using an easy out. Any recommendations on this or another way?
I searched the old threads prior to this posting and did not find much useful info.
2strokeworld.com
Last edit: 27 Sep 2010 19:23 by Kapahulu.
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
27 Sep 2010 19:24 - 21 Feb 2013 20:54
#402339
Last edit: 21 Feb 2013 20:54 by H1Vindicator.
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Stripped Kawasaki emblem screws
27 Sep 2010 19:26
#402340
a very small drillbit,screws are less than an 1/8"
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Motor Head
  • Motor Head's Avatar
27 Sep 2010 19:27
#402341
Only drill enough to remove the head of the screw, a left hand drill bit may back them out. If you take only the head off then soak em and grab with a good "Duck Billed" pliers.
  • porchev914
  • porchev914's Avatar
27 Sep 2010 21:15
#402364
The screws are 3mm. If you can't find an easy-out or left handed drill bit that small, use a 4mm drill bit to take the head off like motorhead suggested. That should do it ;)
FRANKEN Z!
  • Kapahulu
27 Sep 2010 21:40
#402368
Thanks for the great tips. I'll let you know how it turns out.
If I weren't having the tank repainted I'd just leave the emblems on.
2strokeworld.com
  • Kapahulu
28 Sep 2010 23:10
#402632
I managed to drill the heads off two screws and then remove them with a vise grip.
On the other side of the tank, I drilled the heads off and there wasn't enough screw left to grip and remove. Next I tried cutting a small line in the screws and remove them with a regular screwdriver. No dice.
So one side of the tank will have the badges reattached with screws and the other side will have them reattached with glue or double stick tape. The remaining stubs will be used to properly position the badge.
2strokeworld.com
