WHERE DO I FIND A MIX CODE FOR EARLY KAWI GREEN
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: WHERE DO I FIND A MIX CODE FOR EARLY KAWI GREEN
25 Jan 2011 13:20
#425405
scott s wrote:
Hey, look! I used the search function! ;)
I'm thinking about maybe doing an Eddie Lawson inspired replica type paint job for my little KZ250 project.
I've found some cool pics for inspiration and I can use the DupliColor grabber green (close enough for what I want to do).
My question is about the accent stripes. White = easy. But what about the darker stripe? I've seen blue and purple used as the accent stripe. Which is more correct? Is there a DupliColor that's close to the blue? Or is it purple?
Scott...join www.KZ1000R.com and post this same question...you'll find lots of opinions and ideas on that site.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • jeffasaki
  • jeffasaki's Avatar
25 Jan 2011 13:48
#425411
have a look at my bike in my avatar
Ill give ya the paint codes if ya want em
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • gengomerpyle
  • gengomerpyle's Avatar
25 Jan 2011 16:22
#425443
what are the codes? i also would like to know. thanks
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • jeffasaki
25 Jan 2011 17:27
#425459
well here ya go
green= 445.B5
blue= 474.E3
white=GMA-WA9567
done with lesonal
base/clear
Paid a pro painter to lay it would never try paint myself
Not cheap but very nice.
Color matched from a old ELR tank I had the chance to borrow
Cheers
Jeff
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • jeffasaki
25 Jan 2011 17:30
#425461
PS ITS not easy being green so you better get it right
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
25 Jan 2011 18:51 - 13 Feb 2012 19:08
#425515
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 19:08 by KZ250LTD.
  • Tariff
  • Tariff's Avatar
  • Tariff
08 Mar 2011 11:15
#436189
Here is another option if you want your Kawasaki green for a ELR build,racebike,etc.
Ive seen many shades of Kawasaki green on diffrent models over the years,so who is to say whats the correct one....beats me,although going with the shade you like the best is always a good option.I am sure you guys are more knowlagable about these things then I....but here is my 2 cents.
Years ago I used to work at a autobody supply company and I often mixed and matched the customers paint.Sometimes the best you could do for a customer was to get the color close,then take it out into the sunlight to see how close you were and then go back and lighten or darken the mix until you got it spot on.
I also had plenty of time to experiment with my own custom color mixes.And I always had a good supply of custom colors for bike projects.
Anyway,about the time I left that job,I think it was Dupont that came out with it....but they had a small handheld electronic device that they would place on your part with the color you wanted matched,it would take a optical sample from three diffrent spots on your painted part. And the machine would come up with a paint recipe that would match your color.Very close as a matter of fact.And often didn't need any extra tinting.
This might be a option for those that want to have a restoration with the paint identical to the stock/showroom color.When they mix the paint up for you,make sure you get a copy of the paint recipe,and keep it safe.
Hope this helps! Tariff
1984 KZ700A1 Sports
1977 Triumph T140 "Bonnie 750"
1975 Honda CB400f "SS"
and others...
  • kawman14733
  • kawman14733's Avatar
08 Mar 2011 12:41 - 08 Mar 2011 12:43
#436202
if you have a stock panel ov the green wanted or if you can borrow from someone,,, most paint stores can use a cumputer process they get ya the exact coler of that piece in that light condition. and they can mix it, what ever you want base coat clear or single stage urethan . you need a 2x2 inch square for best results,,,steve thats what i did for my 82 elr 1000,,,, just like terif said that i dident read sorry
Last edit: 08 Mar 2011 12:43 by kawman14733.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
08 Mar 2011 13:28
#436215
I've been extensively researching this for the past few weeks. I don't even know where to begin. I sprayed my project with what was supposed to be a match to KX green...Chrysler Go Jolly Green. GJG is too dark, same tone but too dark. Grabber Green is just wrong.
You can't really tell the "exact" color from a computer monitor, that's why I reference 2 colors in the pics.
Chrysler Go Jolly Green on the left, original KX green on the right.
Grabber Green and original KX green.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • kawman14733
08 Mar 2011 17:15
#436294
your looking for more like the 1000r of mine in the middle. if you took that bar on the right to a paint shop it would be matched to that bar but a flat piece would be better to do it with. i could give ya the coler match of my paint if that would help but it was color matched to another 1000r panel if i still have the can , i think i do steve
  • kawman14733
08 Mar 2011 17:26
#436300
this is a gpz painted with the same paint as my 82 1000 r1.. but its a base coat color coat and clear paint dupont expensive paint
  • optmst8
  • optmst8's Avatar
09 Mar 2013 21:37
#576243
Lawman 14733 has the color green I would use!
