windshield info
- coach59
windshield info
23 Aug 2010 21:00
I'm looking for a winshield for my '82 KZ750LTD - and not sure what the specs may be and what other info I may need to know. Any vendor recommendations ?
- TeK9iNe
- What did you do!?!
Re: windshield info
24 Aug 2010 07:16 - 24 Aug 2010 07:18
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 24 Aug 2010 07:18 by TeK9iNe.
- Motor Head
Re: windshield info
24 Aug 2010 07:27
I've got a SlipStreamer SportFire Clear 19" for a 7/8" bar, with all mounting. I went over to a Vetter fairing.
It's on Ebay, Item #330461290715. Its got 1 season of use and is in good shape.
These have a quick release to take it off with just the turn of 2 wingnut clamps. I still have the same in Smoke on my 550.
- steell
Re: windshield info
24 Aug 2010 09:32
First, decide how much protection you want.
Spitfire to just block some wind from your chest, to Plexifairing III that will provide protection to your buddies riding on each side of you (Ok, I exaggerate a tiny bit).
I've had several windshields and have never found the ideal all purpose one.
- hocbj23
Re: windshield info
24 Aug 2010 16:01
EMGO has a pretty nice dolphin style fairing that will work.bj
- coach59
Re: windshield info
24 Aug 2010 18:18
Not sure what size my handle bar is....which part of the bike would I measure the 19 inches from to see if I can see over it ?
- Motor Head
Re: windshield info
24 Aug 2010 18:59
The 19" Spit Fire measures from the tallest point, it has a notch for going around your gauges. I'm 6' and I look over the top, but it blocks a lot of wind. Nothing like a full fairing, and there is others smaller and taller. Rider height and ergonomics will play into windshield selection. The 7/8" is the diameter of the handle bar at the grip/ control area. Stock on a KZ is 7/8", the aftermarket can supply 1" bars but you need the clamps on the trees and all the controls etc.
- coach59
Re: windshield info
24 Aug 2010 21:21
Your e-bay item looks nice - it may be just what I need. I'm going to measure the 19 inchses and see where that puts my vision looking forward. Thanks for the heads-up.
- Motor Head
Re: windshield info
24 Aug 2010 21:25
Yep, would do someone good. I just got spoiled after buying a 1100 that had a fairing, so I had to get 1 for the 1000. These are the longer ride type bikes, I did 3600mi on the 1000 in July. Still like this style for the 550 though.
- coach59
Re: windshield info
24 Aug 2010 22:05
Will I need to adjust anything on the handle bars to get this installed ? BTW - do I need to measure 19 inches from the top of the instrument area - ( as the windshield fits on top of that area )? Also, is the final install slightly slanted towards the driver, or is it straight up ?
- Motor Head
Re: windshield info
25 Aug 2010 06:02
I will angle back, and 19" from outside of the gauges, about 16" from the gauges. @ clamps go around the bar, they have a Allen socket bolt, then there are 2 wing nut quick release bolts for the windshield connection, and adjustment. Depending how many things are on your bars and bar type, if you have the stock bars and controls, then this will fit great, takes about 8 minutes to fit the first time. Once the clamps are there it comes off really fast, and right back on.
- coach59
Re: windshield info
25 Aug 2010 07:12 - 25 Aug 2010 07:13
So if I understand you correctly, the shield actually covers the plastic casing of the gauges in front ( closest to the front tire - and does not just fit around the top of the gauges ? When you say 16 inches from the gauges do yhou mean that I can measure 16 inches from the the glass top of the gauges - and that's where the top will be ? Sorry for all the questions....
Last edit: 25 Aug 2010 07:13 by coach59.
